7.3 mileage - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 117 (permalink) Old 10-03-2009, 02:07 AM Thread Starter
7.3 mileage
i have a 1997 obs f250 with the 7.3 with e4od tranny. It is has no tuner,stock gears, stock exhaust, and 33 inch all-terrains. Im getting about 14-15 mpg. is that normal? what kind of mileage could i expect to get if i installed a tuner and 5 inch exhaust?
ibestrokin97 is offline
post #2 of 117 (permalink) Old 10-03-2009, 02:14 AM
d-man
99coalroller's Avatar
Re: 7.3 mileage
I get anywhere from 16.5-18 in my early 99 scsb, completely stock with a leveling kit and a worn out 4r100. If you can keep your foot out of it a tuner and exhaust will probaby add a mile or two per gallon, but keeping your toes off the go pedal with a chip in the truck is hard to do
2005 F350 CCLB King Ranch, 2.5"' Level, 35" Toyos on 08 20's, EGR Delete, 5" MBRP, Blue Spring, 6.4 Banjos, Rotella ELC
99coalroller is offline
post #3 of 117 (permalink) Old 10-03-2009, 02:41 AM
Old guy from the old days
Believer45's Avatar
Re: 7.3 mileage
Much depends on how you drive. As for "stock gears" you could get 3.55 or 4.10 when yours was built. I have 3.55 gears on a stock truck (except for open element air filter). I recently added a 3 foot tall contractor cap and 800 lbs to it, the figures I have are from before.
I drive like an old man, no more than 1/4 throttle, upshift at 1200 or so RPM (not a typo), I drive like there is an open glass of grape juice in my bed sitting on carpet that cost $175,000 a square yard to install. I often ge beat off the line at red lights by semi trucks with trailers.
Cruise at 75 - get 16-17.5 mpg.
Cruise at 65 - get 18 - 20
Cruise at 57 ( my truck's sweet spot) and personal best is 24.5 over 830+ miles.
Get on it and play, 15.5 - 16 around town, if I recall correctly. It has been 5+ years since I have done this one.
Dave / Believer45
1995 F250 'Stroke 4x2 5 spd long bed, Edge Evolution CTR, homebuilt
, switched 10k, Putco Master Boss running boards, one off heavy duty
, 36" tall contractor cap, 287,000 miles.
for glow plug system help.
Believer45 is offline
post #4 of 117 (permalink) Old 10-04-2009, 02:22 AM
952X4's Avatar
Re: 7.3 mileage
I can get 21-23 with mine running at about 60 mph, I've got 3.55 gears and a 5 speed manual, 4 inch exhaust, 6637 intake and a DP-Tuner chip, mileage is all about how easy you are on the throttle..
952X4 is offline
post #5 of 117 (permalink) Old 10-04-2009, 02:31 AM
Super Hauler!
Super_Hauler's Avatar
Re: 7.3 mileage
I get 21 in my 250 7.3. But 450 i get 12
Super_Hauler is offline
post #6 of 117 (permalink) Old 10-04-2009, 06:28 AM
I helped make ur rimz....
MadMax'97PSD's Avatar
Re: 7.3 mileage
in my '97 7.3L F-250 i get about 13-15 in the city, and about 16-21 on the highway depending on how fast I'm going (when I'm going 50MPH i get about 21, but when I'm going 75-80 MPH i get about 16 or so) do you know what kind of gears you are running in your truck. Mine has 4.10 gears in it, or so i was told by a trusty mechanic buddy. Also is your truck 4X4 or 2wd? because ( someone please correct me if i'm wrong) supposedly that also has an impact on MPG as for the tuner & exhaust , i honestly have no idea, my 250 is pretty much bone stock right now.
'95 F-350 Crew Cab Dually 7.3L. 187k miles - 6637, bitchin aftermarket headlights
'97 F-250 extended cab 7.3L 216k miles-6637, 4in straightpipe
'99 Dodge 2500 Laramie SLT 5.9L 222k miles- flex pipe exhaust, fatal 53 block- fml.
'92 F-350 CCLB 4x4 7.3IDI
Diesel- Fuel 4 Life
MadMax'97PSD is offline
post #7 of 117 (permalink) Old 10-10-2009, 02:46 AM
Re: 7.3 mileage
true the extra weight give less mpg
brendend is offline
post #8 of 117 (permalink) Old 10-10-2009, 04:53 AM
MPG Moderator
Dave Whitmer's Avatar
Re: 7.3 mileage
To answer the original questions:
Yes that MPG is about average for a truck configured like what you describe.
No, a 5" exhaust will not improve your MPG at all. I put a big exhaust on mine and got ZERO improvement.
If you find a special MPG tune you might realize a half to three-quarter MPG gain. With a commercial tuner or chip, expect a loss of MPG. Been there done that.
2000 F-350 SC 4x2 6 speed
Slammed 4"
Rugged Air Dam
315,000 miles
Dave Whitmer is offline
post #9 of 117 (permalink) Old 10-12-2009, 03:57 AM
brandon
bcangelo's Avatar
Re: 7.3 mileage
Dave is the man when it comes to MPG
2002 f-250 7.3 ex cab automatic, 4'' turbo back magnaflow exhaust. tonneau cover. SOLD
2011 f-250 6.7 Lariat fx4 with lots of extras!!Sold
2011 Screw Ecoboost 4x4 with ALL the options
Excuses are like butts, everybody got one and they all stink!
bcangelo is offline
post #10 of 117 (permalink) Old 10-24-2009, 04:20 AM
strokepower's Avatar
Re: 7.3 mileage
I have an 02 6 speed and i get anywhere from 18 to 23 in town blowin all kinds of smoke!! idk how, but i love it!
A chip will definatly get you more mpgs and exhaust will probly do some justice as well as sounding badass!
strokepower is offline
