Non-Sexy MPG Advice - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 67 (permalink) Old 07-29-2007, 11:05 PM Thread Starter
MPG Moderator
Dave Whitmer's Avatar
Non-Sexy MPG Advice
This is about as sexy as John Goodman in a speedo but it definitely works, particularly for heavy pickups.
Keep your tires aired up rock-hard.
This is a must for folks with firebomb tires but it makes a big difference on other brands as well.
I use 235-85 E rated tires and I keep them inflated to 80 psi, front and rear. Any more and the tire starts to "crown" - bulge out in the middle of the tread. That will wear the center of the tire out quickly. Not recommended.
My truck is very sensitive to this. If the tires get down to 70 psi, I lose 1 MPG. At 60 psi, 3 MPG. Ask me how I know that. Don't gundeck the tire inflation.
2000 F-350 SC 4x2 6 speed
Slammed 4"
Rugged Air Dam
315,000 miles
Dave Whitmer is offline
post #2 of 67 (permalink) Old 07-29-2007, 11:07 PM
The Unseen Mod
RescueF250's Avatar
Send a message via AIM to RescueF250
Re: Non-Sexy MPG Advice
well my PJ's say 65psi but it didnt wear right so I played with the air, maybe this time i will leave it at 65psi and see how it goes I used to get good mileage to.
03 Rescue is Dead
08 Rescue - No Limit Fab, MPD, Rescue Diesel, Barder Turbo, Fuel Lab, H&S products.
RescueF250 is offline
post #3 of 67 (permalink) Old 07-29-2007, 11:12 PM Thread Starter
MPG Moderator
Use the max pressure listed on the sidewall. That is generally the crowning pressure. The pressure will be much less for C or D rated tires.
It will ride rough but MPG will improve.
Slammed 4"
Rugged Air Dam
315,000 miles
post #4 of 67 (permalink) Old 07-29-2007, 11:16 PM
Don't EFN worry about it
Aljay's Avatar
In my case I am just fouled I guess. I run 285-75-16s on my stock alum. wheels. I really need 10 " wheels to get proper foot print. My other 97 I had 235-85s and they were aired up to 80 but it was a 2wheel drive and I drove it out of town alot.
Tuned by T Wildman
Aljay is offline
post #5 of 67 (permalink) Old 07-29-2007, 11:16 PM
The Unseen Mod
RescueF250's Avatar
I dont mind the ride I've never had anything smaller then a 33 lol so im used to it. should I back it off some it wears wrong like the center my buddy got 50k on his 38 Pj's
03 Rescue is Dead
post #6 of 67 (permalink) Old 07-31-2007, 01:08 AM
gregrob's Avatar
Same here dave, hard as a rock 80 psi.
Works the best mileage wise and tires last the longest for me this way.
gregrob is offline
post #7 of 67 (permalink) Old 07-31-2007, 01:14 AM
AllYourBaseAreBelongToUs
imelmo's Avatar
Maybe that's part of why I only get about 14mpg. I ride around at race psi front and rear everywhere.
EMPIRE DIESEL, PERFORMANCE TRUCK PRODUCTS, CEN-TEX DIESEL PERFORMANCE, AND DIESEL INNOVATIONS
ALSO LOTS OF HELP FROM (IN NO PARTICULAR ORDER) TWISTED DIESEL PERFORMANCE, FCDP, ITP, MATT WITH GEARHEAD, ERIC WITH INNOVATIVE, DOUG WITH GOGO DIESEL, CASS WITH FULL FORCE DIESEL, AND SWAMP'S
2005 F350 Fat-Butt Truck
2004 ECSB Procharged F250
imelmo is offline
post #8 of 67 (permalink) Old 07-31-2007, 01:22 AM
Hog Whisperer
tater97's Avatar
Ok I got a 6700lb F250 I run Yokohama geolanders 285 75 16. wHAT do I run front pressure and rear pressure for good ride and best tread wear? At 600 for four I need to know. Tate
1997 Ext. 4x4 5 spd, All green finally!,Beans 1's, Tymar, 3"-4" DP Exhaust, Shimmed FPr 1.0 Turbo,6Pos TONY WILDMAN burn. Okiecooler, ccv mod, SouthBend ConFE,superduty spring packs,17* hpop
Number19
tater97 is offline
post #9 of 67 (permalink) Old 07-31-2007, 01:33 AM
Carolina Kracker
quick26's Avatar
i have been running 55 in my 305s the max it 65
I am not post whoring, I am providing an over abundance of useless opinion.
03 F-350 Lariat CC SB with 6.0
Zoodad, K&N intake, Acufab elbow, MBRP 4" 409 turbo back, SCT tuned by Innovative Diesel, Dual front shock mounts, front add a leaf, eagle wheels with nitto 305 70 16s. 5% tint, linex liner and upgraded audio and video inside
quick26 is offline
post #10 of 67 (permalink) Old 08-01-2007, 08:30 PM Thread Starter
MPG Moderator
Every tire has a max pressure on the sidewall. Use that pressure.
Slammed 4"
Rugged Air Dam
315,000 miles
