Hydrogen guys-what are you using for your solution? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 46 (permalink) Old 09-09-2009, 03:37 PM Thread Starter
Junior Mint
My Hydrogen system has for months been dropping AMPs which of course means it's producing less and less Hydrogen.
I have flushed it out multiple times and tried many different concoctions to no avail.
What are you guys using for solution?
Currently I'm running distilled water w/ KaHO and only getting about 1-2 AMPs. Increasing the KaHO concentration seems to have little to no effect at all.
Also, my solution turns bright rust colored after a week or so.
I'm lost. Thanks.
I'm officially...Stroke-less.
Suns_PSD is offline
post #2 of 46 (permalink) Old 09-09-2009, 09:52 PM
06powerstroke's Avatar
Re: Hydrogen guys-what are you using for your solution?
I was talking to a customer today that built his hydrogen systems in his cars and he said he runs Potassium Chloride as a solution. Getting 5 amps out have his system and it seems to work really well.
2006 F250 CC LB FX4 Lariat
ARP studs, SCT X3 IDP & Gearhead tuned, S&B CAI, straight pipe, FASS 150/180, FCDP solid uppipe, Dieselsite coolant filter
2.5" BTS leveling kit, 35" Xtreme A/T's on XD Hoss 18's, N-Fab prerunner bar w/ 3 9" Hellas
Pioneer double din, JL components, 3 10" Pioneer subs
06powerstroke is offline
post #3 of 46 (permalink) Old 09-09-2009, 10:10 PM
theSLEEPER's Avatar
Subscribing. Been interested in the hydrogen thing.
theSLEEPER is offline
post #4 of 46 (permalink) Old 09-09-2009, 10:19 PM
Well let me tell you about this guys setup then. Right now he currently has it on his Prius. He says it doesn't add much mileage, but you can feel the power kick when he flips the switch!
He has 4 homebuilt reservoirs in the back with 2 deep cycle Optimas providing current. There is a small alternator running off the back wheel to charge the batts. Each battery has a + and - electrode in each of the reservoirs. He has a Voltmeter and ammeter on his dash to monitor. Up front are various switches and other things to control the flow and electrolysis. The system pulls the hydrogen into the motor using engine vacuum. He also wired a switch to fool the MAF into cutting fuel so it will run mostly on hydrogen.
post #5 of 46 (permalink) Old 09-09-2009, 11:49 PM
Failure to Communicate
highfive's Avatar
I'm lost. Thanks.
Are you able to look at what is inside your container or just what drains out?
With all the rust you are making I would bet that whatever stainless material they used is getting eaten away to nothing. We made a few different ones and found that some of the stainless starts eroding right away and making the "rust", some types of stainless worked better than others but were harder to work with so I have found they have to be replaced after a month or two to keep producing. You would be amazed at how much material is lost in that time.
96 F250 CC SB 4x4
DIY or Die Tryin-Fuel, Trans, Lifted and Stroked
highfive is offline
post #6 of 46 (permalink) Old 09-10-2009, 12:28 AM
<-- it's like that
Let me know when he burns his engine up.
Curtis
2002 F-250 PSD
Gambling with 250/200's on PMR's.
478hp/851tq on Haller's dyno - 7/28/12
Your connection to the
Pocket is offline
post #7 of 46 (permalink) Old 09-10-2009, 12:44 AM
I thought that was kinda strange too. He doesn't completely cut fuel, just slows it down...
I was always told the 02 sensor would see the extra richness from the extra fuel and cut fuel by itself...
post #8 of 46 (permalink) Old 09-10-2009, 06:03 AM
<-- it's like that
If he were shoving that much hydrogen in, then yes it would.
By fooling the O2 sensor, he is leaning out the engine. In addition, he is not metering his fuel accurately, so he has no idea what his mixture is. Lean gasser = higher EGT's.... eventually resulting in premature engine failure.
Curtis
2002 F-250 PSD
Pocket is offline
post #9 of 46 (permalink) Old 09-10-2009, 06:29 AM
ADubDiesel's Avatar
X2
1995 Ford F-250 7.3 (Sold)
1998 Nissan Maxima 3.0
ADubDiesel is offline
post #10 of 46 (permalink) Old 09-11-2009, 05:02 PM Thread Starter
Junior Mint
I agree that rust is the ultimate culprit in why I have lost amps.
I will figure out how to open the system and figure out where the corrosion is coming from. Hopefully they just used steel bolts somewhere and that is the problem.
What grade of stainless should one use and where can I get it?
Suns_PSD is offline
