Dually MPG ??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 08-14-2009, 08:21 PM Thread Starter
Dually MPG ???
Can someone tell me what size my tank is my truck is in my sig. I'm under the impression that its a 36 gallon. If thats the case then my gas mileage doesn't seem to good. I've only been able to get about 450 miles out of a tank thats a mix of hwy and city and if I'm doing my math correctly thats about 12.5 miles to a gallon. I don't lead foot it cause my tranny is questionable and I'm trying to hold on to it as long as I can.
Thanks
jgos929 is offline
post #2 of 16 (permalink) Old 08-14-2009, 09:05 PM
06powerstroke's Avatar
Re: Dually MPG ???
I would say 36 gallon. 12 doesn't sound that bad. I'm not actually sure what is expected with a 7.3. Your rear gearing will also affect it. 3.73, 4.11, 4.88. We have a 6.4 with 4.88's and it gets 10.5.
2006 F250 CC LB FX4 Lariat
ARP studs, SCT X3 IDP & Gearhead tuned, S&B CAI, straight pipe, FASS 150/180, FCDP solid uppipe, Dieselsite coolant filter
2.5" BTS leveling kit, 35" Xtreme A/T's on XD Hoss 18's, N-Fab prerunner bar w/ 3 9" Hellas
Pioneer double din, JL components, 3 10" Pioneer subs
06powerstroke is offline
post #3 of 16 (permalink) Old 08-18-2009, 04:25 AM
secondarychaos's Avatar
Re: Dually MPG ???
You don't needs to know the size of your tank to get your mileage. take your mileage from fill up and top-off to the next fill up and top-off, and use the second fillup's gallons to find your mileage. that's the only thoroughly accurate way.
Dan
96 Powerstroke: 6637, downpipe to dump exhaust, 140v IDM and a shift kit.
84 Honda Sabre V65 1100: pipes, jet kit and new tires. Faster than I think I'll ever need.
secondarychaos is offline
post #4 of 16 (permalink) Old 08-18-2009, 02:18 PM
Coming For You
"THE DEMIZE"'s Avatar
Send a message via Yahoo to "THE DEMIZE"
Re: Dually MPG ???
I have a 2000 ex cab dually with 3:73 and a 6 speed and I get a good 20 just puttin around
97 F-350 cc lb 4x4
Swamps,Carson,Beans,Unlimited
"THE DEMIZE" is offline
post #5 of 16 (permalink) Old 08-18-2009, 10:48 PM Thread Starter
Re: Dually MPG ???
What???
I would think if you filled it up with 36 gallons ran it to E and filled it back up with close to 36 gallons then divided by your trip miles that would be the accurate way.
jgos929 is offline
post #6 of 16 (permalink) Old 08-19-2009, 12:20 AM
Re: Dually MPG ???
Originally Posted by jgos929 View Post
What???
No this is how it works. You fill up, drive say 500 miles. Then you fill back up, I will say 32 gallons just as a demonstration. Then you do 500/32 and you get 15.6mpg. See how that works?
post #7 of 16 (permalink) Old 08-25-2009, 12:10 AM
Re: Dually MPG ???
For what its worth, although it is a moot point, I believe you probably have a 38 gallon tank.
early '99 converted to late '99 F-350 dually, 4x4, 4 door, long bed, 6 speed. Midwest transmissions 05+ zf-6 transmission with their short throw shifter and SB clutch. Rosewood 180cc singles with 80% nozzles, Termy modded 17* HPOP, International bellowed up pipes, fs-2500, DP Tunes.
calebgriffin31 is offline
post #8 of 16 (permalink) Old 08-27-2009, 09:10 PM Thread Starter
Re: Dually MPG ???
What??? You just quoted me saying the same thing as your saying now.
Thanks that makes me feel even better
jgos929 is offline
post #9 of 16 (permalink) Old 08-27-2009, 11:11 PM
Re: Dually MPG ???
you made it sound like you wanted to just use the size of your tank, which is inaccurate
Dan
post #10 of 16 (permalink) Old 08-27-2009, 11:19 PM
you want some of this?
smorris's Avatar
Re: Dually MPG ???
What he is saying is , it makes no difference what size tank you have.
Just be sure you use the amount of gallons used since last fillup, and the miles driven since last fillup. The size of the tank matters not.
Whether you use 20 gallons or the full 38 or so gallons just use the actual number of gallons you put back in there.
Oh, and if its the factory tank it supposed to be 38, but I have put more than 40 in mine many times. 41 and a few times 42 gallons.
example "a"
drove 100 miles used 10 gallons of fuel= 100/10 = 10 miles to the gallon
example "b"
drove 400 miles used 40 gallons= 400/40 = 10 miles to the gallon
so you see the tank size doesnt matter at all.
2000 f-350 cc lb dually 4x4, BTS transmission
[email protected] 90 mph on MT mud tires and 8,000 #
coming soon--97 cc lb 4x4
smorris is offline
