Need A Little Help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 08-07-2009, 06:21 PM Thread Starter
MPG Moderator
Dave Whitmer's Avatar
Need A Little Help
Finally got off my fat butt and started testing if paddle mirrors give better MPG than TT mirrors. Looking at the relative size... I don't know.
My problem is that I've never changed mirrors. I got the nuts loose but the electrical connector is down in the door. How do I get the door inside panel off enough to get at the connector? Do I have to pull the whole inside panel off?
Help!
Anybody in the Indianapolis area wanna help? Beer can be provided.
2000 F-350 SC 4x2 6 speed
Slammed 4"
Rugged Air Dam
315,000 miles
Dave Whitmer is offline
post #2 of 19 (permalink) Old 08-07-2009, 06:38 PM
Banning Smut
PTSUPERD's Avatar
Re: Need A Little Help
Dave. The door panel is very easy to remove. I think its 2-3 screws. 1 behind the door light/reflector and the other under the armrest if I remember right. With the panel off...peel the plastic back and the harness is easy to get to.
PTSUPERD is offline
post #3 of 19 (permalink) Old 08-07-2009, 06:58 PM
DILLIGAFF
Send a message via AIM to Redfish
I also believe you have to pop off the little black piece on the forward most part of the window to get it off.
2006 F-250 CC King Ranch, Harley Headlights w/ 55w HIDs
ARP studs, MBRP 4" exhaust and AM Colbalts By:
, AFE stg. 2 Pro Guard 7 from XDP, SCT from innovative!
14.09 @ 94 1.85 60'
Redfish is offline
post #4 of 19 (permalink) Old 08-07-2009, 07:04 PM
Banning Smut
PTSUPERD's Avatar
Yep. Two or three nuts behind there.
PTSUPERD is offline
post #5 of 19 (permalink) Old 08-10-2009, 01:40 AM Thread Starter
MPG Moderator
Thanks, PTSUPERD. It was the one in the light that had me buffaloed.
Gotta be real careful getting the nutwashers off so you dont drop them down into the door.
Should have results in a couple or three weeks. Baseline was 26.32 MPG with TTs.
Slammed 4"
Rugged Air Dam
315,000 miles
post #6 of 19 (permalink) Old 08-10-2009, 01:42 AM
jaybuller's Avatar
im gonna guess 26.50
2000 f250 ECSB Dually 4.10s 305/70/16, 4x4 7.3 zf6 200k miles
Php hydra chip PHP tuned! 4" exhaust, stock turbo(ww2, turbomaster wastage actuator, gutted ebpv), FRX, 160/30 sticks SB 1939-CB single clutch, home brew water setup for when i'm pulling hay through the mountains.
jaybuller is offline
post #7 of 19 (permalink) Old 08-10-2009, 01:47 AM Thread Starter
MPG Moderator
Don't know. Aero improvements can be unpredictable. The paddle mirrors look to be about the same frontal area as the TTs, but just hug in closer.
If anyone gives a rip, I look to be at Scheid's event end of the month. I should have some numbers by then.
Slammed 4"
Rugged Air Dam
315,000 miles
post #8 of 19 (permalink) Old 08-10-2009, 01:53 AM
Don't EFN worry about it
Aljay's Avatar
Nice info !!
Tuned by T Wildman
Aljay is offline
post #9 of 19 (permalink) Old 08-10-2009, 02:05 AM
OBS junkie
Cat_Rebel's Avatar
If your going to Scheids for sure let us all know, we'll be there.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #10 of 19 (permalink) Old 08-10-2009, 11:01 PM Thread Starter
MPG Moderator
Barring something out of my control I plan to be there Fridat, August 28, hopefully before 11:00 A.M. Terrible Hotel is a couple hours from where I live.
Slammed 4"
Rugged Air Dam
315,000 miles
