anyone tried gear vendors overdrive? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 24 (permalink) Old 06-27-2009, 06:03 PM Thread Starter
jaybuller's Avatar
Im just looking at all the different options on tranny and mpg stuff. i am thinking about switching to a 6 speed but was wandering if anyone has used a gear vendors on one of these trucks? It would be able to drop the rpms way down low at 65 or 70 mpg i beleive you would be able to run 1500 rpms at 65 mph. Lets hear your thoughts on this.
2000 f250 ECSB Dually 4.10s 305/70/16, 4x4 7.3 zf6 200k miles
Php hydra chip PHP tuned! 4" exhaust, stock turbo(ww2, turbomaster wastage actuator, gutted ebpv), FRX, 160/30 sticks SB 1939-CB single clutch, home brew water setup for when i'm pulling hay through the mountains.
jaybuller is offline
post #2 of 24 (permalink) Old 06-27-2009, 06:23 PM
Super Hauler!
Super_Hauler's Avatar
Re: anyone tried gear vendors overdrive?
I have looked into this for my 450 with 4.88 gears, it would really help on highway. I just cant find any around here unless i plan on spending a life savings.
Super_Hauler is offline
post #3 of 24 (permalink) Old 06-28-2009, 02:35 AM
MPG Moderator
Dave Whitmer's Avatar
I've looked into it. (Surprise!)
The GV is a quality unit (be sure and grommet the wires where they go throughthe firewall) and it is fairly bulletproof.
It is a 0.8:1 OD. If your 6 speed with 3.73 gears and OEM rubber is turning 2 grand at 70 MPH, it would knock your engine speed down to 1600. I'd expect a 3 MPG improvement. The PSD has plenty of torque for that RPM.
Problem is that the GV is eye-wateringly expensive and you never find them on craigslist. The 4x2 version costs $5,000.
It would be less expensive (for a 4x2) to get a T-56 Viper tranny with its huge 0.5:1 overdrive. That would reduce your top gear engine speed to 1400 [email protected] MPH.
2000 F-350 SC 4x2 6 speed
Slammed 4"
Rugged Air Dam
315,000 miles
Dave Whitmer is offline
post #4 of 24 (permalink) Old 06-28-2009, 02:56 AM Thread Starter
jaybuller's Avatar
yeah i didnt realize the price was so outragous. I tink i would rather just get a couple less mpg than buy the gear vendors now that i see the cost.
post #5 of 24 (permalink) Old 09-23-2009, 01:23 AM
Fordooredwhore
twisted's Avatar
I just called GV $3050.00 shipped to my door.
twisted is offline
post #6 of 24 (permalink) Old 09-23-2009, 05:03 PM
Cowboy Up
I looked into it but it is only gauranteed to 30,000lbs gcvw. I guess if you don't tow anything heavy and only want it for mpg then it would be ok.
'96 F350 CCLB, Dually, 4wd, ZF6, 4.10's, 4" lift, Energy suspension and body bushings, Firestone airbags, 245/70R19.5, 3" DP, 4" MBRP straight pipe, Afe stage 2, TW 6 pos, Autometer gauges, Valair kevlar/ceramic clutch, Stage 1's, Shimmed FPR, Gutted EBPV, Welded pedestal, CCV mod, SD 7.3 intercooler, D66 Turbo, 17* HPOP
INTPSTROKE96 is offline
post #7 of 24 (permalink) Old 09-23-2009, 05:14 PM
guy i know has it on his 6.0 cc drw 4x4 and he loves it, hes also running 4.10s and does pull heavy loads. so far he has hauled dozers, skidsteers, some rigging equipment.......so far it has held up.
02 f250
countryboyrob is offline
post #8 of 24 (permalink) Old 09-23-2009, 05:26 PM
FREE THINKER
Chip's Avatar
Just wondering,what is that on the front of the truck in your avitar?
1999 7.3, 2wd ,auto
Chip is offline
post #9 of 24 (permalink) Old 09-23-2009, 05:27 PM
on dave truck that is an airdamn
02 f250
post #10 of 24 (permalink) Old 09-23-2009, 05:28 PM
Lovin the Tuna
RedSmokey's Avatar
would be awsome, but that tranny wont last long with the torque of a diesel...
2001 F250
2000 F250
RedSmokey is offline
