bad mileage - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 11-25-2007, 04:33 PM Thread Starter
IH_deere_slayer's Avatar
bad mileage
now i didnt exactly buy a one ton dually with 4.10s to get good mileage. however 12 mpg empty and 9 mpg towing seems a bit low. no matter what tuning i run i always get the same results. i have never seen higher than 13 highway. everyone i talk to says they get 15 or better even with the same set up i have. so are they bs ing me or is my truck not right?
2011 3500 HD Duramax
2006 T800 KW Daycab ISX Cummins
IH_deere_slayer is offline
post #2 of 18 (permalink) Old 11-25-2007, 05:33 PM
Re: bad mileage
I have 373's and i have seen 18-19mpg unloaded if i stay at or just under 2k rpm's, I believe that puts me at around 68-70mph. When it gets cold and its loaded (7k) i am around 15-16mpg. The biggest thing is trying to deal with staying at or under the 2k rpm's.
speediseverything is offline
post #3 of 18 (permalink) Old 11-25-2007, 06:32 PM
MPG Moderator
Dave Whitmer's Avatar
Re: bad mileage
A dually with 4.10 gears and big wheeels, 4x4, and an automatic.
You are about par.
2000 F-350 SC 4x2 6 speed
Slammed 4"
Rugged Air Dam
315,000 miles
Dave Whitmer is offline
post #4 of 18 (permalink) Old 11-25-2007, 06:34 PM
<----Colin Banks
mattymx's Avatar
Re: bad mileage
With those 19.5's, I bet they are taller than stock. Right? If so that might be where the difference is coming from. Your speedo could be off giving you the impression of lower MPG's. You need some good ol' 2 stroke premix in the fuel...
mattymx is offline
post #5 of 18 (permalink) Old 11-25-2007, 07:16 PM
Re: bad mileage
Things that might help for little to no expense. I would guess 3mpg gain with these maybe more depending on your current setup.
1. 203* t-stat
2. stay under 2k rpm's
3. Tires at max press
4. Stanadyne Perf formula.
post #6 of 18 (permalink) Old 11-25-2007, 07:57 PM
Don't EFN worry about it
Aljay's Avatar
Re: bad mileage
I seem to get different mpg from diff. fuel stops. Must be diff. cetane ratings or diff. grades of diesel try docoring your fuel(Add a cetane improver) see if your mpgs go up or down.
Tuned by T Wildman
Aljay is offline
post #7 of 18 (permalink) Old 11-25-2007, 09:54 PM
<----Colin Banks
mattymx's Avatar
Re: bad mileage
2 stroke premix. Try it at 1oz per gallon of diesel.
mattymx is offline
post #8 of 18 (permalink) Old 11-26-2007, 12:08 AM
OBS junkie
Cat_Rebel's Avatar
Re: bad mileage
I'd try the 2 stroke & try the best that you can to keep it below 2000 rpms. Your right, it does seem like you should do more like 14 or so.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #9 of 18 (permalink) Old 11-26-2007, 12:17 AM Thread Starter
Re: bad mileage
ive got a 203 thermostat in it, the tires are only 1 size bigger that stock, this was the same mileage when i had 16 in wheels
post #10 of 18 (permalink) Old 11-26-2007, 03:48 PM
Re: bad mileage
I am having similar issues...
I seem to get around 12mpg(once got just shy of 14)...
The more I read, the more it seems wrong...
AND, I spend quite a bit of time at highway speeds, and under 2k on the highway..
Straight piped, zoodad, etc... no chip, or anything fun yet..
Chase
chasespeed is offline
