2010 6.4 mpg issues - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 04-20-2014, 05:14 PM Thread Starter
2010 6.4 mpg issues
I have a 2010 f250 with the 6.4. Mods are dpf delete, egr delete, turbo back exhaust, intake , spartan tune running 275 early lock. I have 37" tires on 22" rims. Gearing has been changed from 355s to 411s. Now here's the problem, gradually I have noticed the mpg getting worse and power seems to be dropping as well. Looking for and advise or ideas here cause I'm stumped
Kminton85 is offline
post #2 of 4 (permalink) Old 04-22-2014, 02:58 PM
MPG Moderator
Dave Whitmer's Avatar
Re: 2010 6.4 mpg issues
Did you read the stickies.
What you're doing wrong: Big tires and higher (numerical) gear ratio.
I'm not at all suprised your MPG is going down.
2000 F-350 SC 4x2 6 speed
Slammed 4"
Rugged Air Dam
315,000 miles
Dave Whitmer is offline
post #3 of 4 (permalink) Old 04-22-2014, 03:03 PM
Chachi
7.3PowerStroke602's Avatar
, and on that tune you probably drive with a lead foot... which Is another cause of ur mpg decrease
2003 F350 7.3 Turbo Diesel
Rancho 9000 Shocks
4 inch exhaust into Soflo diesel 7 inch Mitre Stack
AFE Stage 2 Cold Air Intake
Glowshift Gauges-Fuel Pressure,Boost,Exhaust Temp. Aeroforce Interceptor Gauge on the Column
Swamps TS 6 Position Chip
Leveled Height with 35 Nitto Mud Grapplers
Swamps Diesel Boost Fooler
7.3PowerStroke602 is offline
post #4 of 4 (permalink) Old 04-23-2014, 03:16 PM
MPG Moderator
Changing the nut behind the wheel (aka the driver) can make up for a multitude of sins.
I have a mild Swamp Donkey tune and I get about the same MPG as his MPG tune. I am a half-baked hypermiler (mostly I'm Sir Coastalot) and that might be why the performance tune and the MPG tune get the same MPG for me.
Having big tires and a numerically higher R/P ratio and visions of being Tony Stewart would lead to lower MPG.
Slammed 4"
Rugged Air Dam
315,000 miles
