MPG Feedback - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 04-07-2014, 05:14 AM Thread Starter
Kevin W
MPG Feedback
Ok, so I just want to see if I'm on with my MPG or low or what. Sig says what the truck has, I am pulling a 40' 5er, dual slide outs, gross weight at 22,500. I was averaging 10-11 mpg, 850-1050 egt, 180-190 trans, 200 coolant, pulling at average 60 mph at 1900rpm. I am also using fuel from on Ft Lewis with 5% biofuel. Pulling in the Northwest Washington, south of Olympic Forest, Air temp approx. 55. Any feedback would be great. Thanks.
Kevin
96 F350 CC SRW 4x4 7.3 E4OD 4.10
273,000
6637 Air Filter
EBPV wired to switch
BB mod
Western GPR
Swamps IDM
3" down pipe, 4" straight AFE
TS 6pos chip
Glowshift Gauges
Kenwood Stereo System with 10" sub
Pyle Alarm system
Kevinwatts is offline
post #2 of 7 (permalink) Old 04-11-2014, 07:45 PM
Re: MPG Feedback
I'd say if you're getting 10-11 MPG towing at that gross on the highway, you're doing real well!
--Nate
'97 F350 CCLB, 4x4 PSD, ZF5
DIYMechanic is offline
post #3 of 7 (permalink) Old 04-12-2014, 02:23 AM
300,000 and counting's Avatar
Re: MPG Feedback
With my mods and 33" I get about 13mpg int town, 15 on the highway. Towing I got 11mpg with a 28' empty trailer (average speed 80) and tow the 8 ton tractor back (averaging 67mph) I got 9 mpg your doing pretty good.
2001 7.3 PSD, Swamps 200/30 injectors, 38r turbo, HPx, FRx, bellowed up-pipes, non-ebpv ped, Gearhead tuned TS 6 pos chip, AFE big boost intake, 4" downpipe; 5" exhaust, BTS valve body, 31 row tranny cooler, autometer gauges, 05-07 front end, centurion rear bumper, 327,000 miles FOR SALE
2009 6.4 PSD, 71mm LP, studded, delete, H$S Mini Max
300,000 and counting is offline
post #4 of 7 (permalink) Old 04-16-2014, 09:09 PM
Re: MPG Feedback
I grew up here and maybe you mean capitol forest, or olympic national park? Regardless. I tow a 30 foot RV trailer that only weighs around 7500. 10-12 is the range of mpg I can get. Compared to a big gas engine at 6 we're doing great but these things need to burn fuel to move such trailers.
2000 F350 SRW, 4wd, CCSB, PSD
Lowered rear end to F250 height, 4" exhaust w/ muff, foil delete, AIH delete, Ford AIS intake, tru-cool trans cooler, autometer under dash pod and gauges, Mile Marker hubs, 04 headlights, soft tonneau
18' 10k rated PJ car hauler
26' 7500# Creekside RV Trailer
Kioti CK30 tractor
Highbeam is offline
post #5 of 7 (permalink) Old 07-19-2014, 03:49 PM
Re: MPG Feedback
Your mileage is about right, lots of aero drag with 5th wheel but your trans temps are pretty high. Towing 22k we rarely see over 160* at 85* degrees much less at 55. Might consider a tru-cool or a 6.0 trans cooler and protect your transmission.
hoschtonhauler is offline
post #6 of 7 (permalink) Old 07-19-2014, 11:18 PM
96powerstroker's Avatar
Re: MPG Feedback
Seems normal
Sent from AutoGuide.com App
96 F250 2WD, 286K, Built E4OD, 180cc Injectors, Tony Wildman Tunes, Beans Fuel System, 3in DP - 4in MRBP exhaust, CAI, 4:10LS SCLB, Traction bars,
62 F250 4X4, 223 I6, T98 4 speed, 4:56s RCFS (Reg Cab Flare Side. Factory) 31x10.50x15s, currently on 16in Alcoas
96powerstroker is offline
post #7 of 7 (permalink) Old 07-29-2014, 09:48 PM
International Coal Roller
jbwaldrop88's Avatar
Re: MPG Feedback
Sounds like your about right on mpg's, that trailer is like a giant airbrake so your actually doing good
02 250 CCLB, 6 spd, PHP Phoenix, ISSPROs, AFE/6637 intake, 4" DE straight exhaust, WW, coolant filter with ELC, AIH delete, ebpv delete, bellowed uppies, 4" on 35's and racelines
jbwaldrop88 is offline
