Split Shots MPG - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 06-06-2009, 02:34 AM Thread Starter
Hillbilly
Htrn38's Avatar
Split Shots MPG
How much would stage one split shots drop my MPG?
Travis
2000 7.3
AFE stage 2, Stage 2 injectors 160/100, GTP38R with WW2, DP-Tuner Stock Hi-Idle 60tow 80Eco 120 Race 140 Aggressive, 4in. Exhaust, Coolingmist water-meth
Htrn38 is offline
post #2 of 10 (permalink) Old 06-06-2009, 03:43 AM
MPG Moderator
Dave Whitmer's Avatar
Re: Split Shots MPG
Split-shots as opposed to single shot won't affect MPG at all. Iwent the other way and saw no measureable improvement in MPG.
"Stage 1" tells me you are looking at a case of leadfoot. That will hurt MPG.
2000 F-350 SC 4x2 6 speed
Slammed 4"
Rugged Air Dam
315,000 miles
Dave Whitmer is offline
post #3 of 10 (permalink) Old 06-07-2009, 03:50 AM Thread Starter
Hillbilly
Htrn38's Avatar
Re: Split Shots MPG
What injectors would you run to get a little more power out of the truck and keep the milage up?
Travis
2000 7.3
Htrn38 is offline
post #4 of 10 (permalink) Old 06-07-2009, 05:07 AM
jaybuller's Avatar
Re: Split Shots MPG
i went with swamps stage one single shots. i went from 16mpg to 19mpg with the stage 1s and php fule sipper tune , yuned for the single shots. I also have about 350rwhp now witch is about 50 or 60 more hp than i would have with the old split shots i did have.
2000 f250 ECSB Dually 4.10s 305/70/16, 4x4 7.3 zf6 200k miles
Php hydra chip PHP tuned! 4" exhaust, stock turbo(ww2, turbomaster wastage actuator, gutted ebpv), FRX, 160/30 sticks SB 1939-CB single clutch, home brew water setup for when i'm pulling hay through the mountains.
jaybuller is offline
post #5 of 10 (permalink) Old 06-07-2009, 11:50 PM
MPG Moderator
Re: Split Shots MPG
Single shots may help if your truck is a fuel hog. Mine had good MPG, so the injectors didn't help.
Swamp is the best, though.
Slammed 4"
Rugged Air Dam
315,000 miles
post #6 of 10 (permalink) Old 06-09-2009, 02:42 PM
Re: Split Shots MPG
I bet more of the MPG increase came from replacing worn out old injectors with brand new ones.
2006 Dodge 2500 MegaCab, 4x4, Auto, 5.9L CTD
SOLD-2001 F250 Lariat CC SB 4x4 auto, 207,000 miles, linex, DP tuner 40T, 80E, 120R. 3.5 inch DP/4 inch exhaust. ATS housing. AFE stage 1, Hutch and Harpooned, HV IDM. V-10 transmission cooler. Medium build transmission. Baby terminator single HPOP, Turbomaster wastegate, 1.0 exhaust housing.
tch.280 is offline
post #7 of 10 (permalink) Old 06-09-2009, 02:44 PM
Re: Split Shots MPG
More HP when your towing or when your playing?
And in general keeping the MPG up is in your discipline and the tuning.
tch.280 is offline
post #8 of 10 (permalink) Old 06-11-2009, 03:46 AM Thread Starter
Hillbilly
Htrn38's Avatar
Re: Split Shots MPG
Both
Travis
2000 7.3
Htrn38 is offline
post #9 of 10 (permalink) Old 06-16-2009, 12:44 AM
Non Helpful Member
Deerezilla's Avatar
Re: Split Shots MPG
I had stage 2 splits in my obs with 3.55 and got 17 every day and 19 on the freeway
2 fords that make no power
Deerezilla is offline
post #10 of 10 (permalink) Old 06-16-2009, 02:00 AM
Harry Callahan
Re: Split Shots MPG
There was some discussion here, first ever thread in this section Splits vs. Singles - Powerstroke Nation
RDRCM#10
A select band of brothers- We stand together as one.
Giant VT-3, not stock
sniperonhigh is offline
