2 stroke oil - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 296 (permalink) Old 07-27-2007, 12:06 AM Thread Starter
gregrob's Avatar
2 stroke oil
Who's running it?
I have been and my truck starts way smoother and quieter, injector tap is very quiet, and I get about 2MPG out of it.
I recommended it to diezel dawg and he had similar results, right around 2mpg.
Who else is running it?
gregrob is offline
post #2 of 296 (permalink) Old 07-27-2007, 12:11 AM
7.3 PSD Mythology Expert
Powerstroke Racer's Avatar
Re: 2 stroke oil
What ratio?
David Lott
Experience is what you get when you don't get what you want!!!
No purpose no happiness, know purpose know happiness ---> Happiness is a direction not a destination.
Powerstroke Racer is offline
post #3 of 296 (permalink) Old 07-27-2007, 12:17 AM Thread Starter
gregrob's Avatar
Re: 2 stroke oil
1oz/gallon
needs to be ashless 2 stroke oil, usually marine is ashless
I use the super tech stuff at walmart, like 8 bucks a gallon.
gregrob is offline
post #4 of 296 (permalink) Old 07-27-2007, 12:28 AM
Re: 2 stroke oil
i'll have to try it, my mileage sucks. burned right at 100 gallons for a 1300 mile trip last weekend, so an extra mpg or two would be nice.
2013 ccsb 4x4-stock
99 ccsb 4x4- built to the hilt, wife's DD!
Short Bus is offline
post #5 of 296 (permalink) Old 07-27-2007, 12:42 AM Thread Starter
gregrob's Avatar
Re: 2 stroke oil
Yep, it's good stuff. I'll be using it from now on. Gonna experiment with some other stuff soon, but this is working great now.
Advantages:
low freeze point, serves as anti gel
better than trans fluid, designed to burn where trans fluid is not
lubricates injectors for long life and troublefree operation
increases fuel mileage due to added lubricity and btu content
lubricates and protects entire fuel system.
better than most fuel additives because they are mainly Xylene or Mineral Spirits, yuck!
One thing alot of folks may not know is that with the introduction of ULSD, the minimum lubricity standard changed (lowered). The process of removing sulfur from the fuel strips away lubricants. In order to even meet this new, lower standard, refiner's created an additive pack that is put into your fuel by the delivery driver!
Here is an awesome link that explains it more in detail and better than I can.
Take the time to read, very worth it!
http://www.frontiernet.net/~mopar197..._cycle_oil.htm
I'm gonna try to get him over here....
gregrob is offline
post #6 of 296 (permalink) Old 07-27-2007, 12:54 AM
Carolina Kracker
quick26's Avatar
Re: 2 stroke oil
i was pondering that idea the other day but was worried about it gumming up the turbo on the way out
quick26 is offline
post #7 of 296 (permalink) Old 07-27-2007, 12:57 AM Thread Starter
gregrob's Avatar
Re: 2 stroke oil
nope
gregrob is offline
post #8 of 296 (permalink) Old 07-27-2007, 01:40 AM
cota's Avatar
Re: 2 stroke oil
Air you using 2 stroke oil that your supposed to mix with gas or 2 stroke motor oil from wal mart?
2000,CC,4x4,auto
some bolt on stuff from Bean & BTS
Some used and some home made stuff
463hp/991tq 10/01/05 mustang dyno 10k rollers
458hp/923tq 04/14/07 dynojet dyno
490hp/1025tq 03/08/08 mustang dyno 10k rollers
03/08/08 1st runs ever, 13.5 & 13.264 @ 100.65mph screwing up both launches, 7600#'s, #2 only
cota is offline
post #9 of 296 (permalink) Old 07-27-2007, 02:58 AM Thread Starter
gregrob's Avatar
Re: 2 stroke oil
I don't know what 2 stroke motor oil is...
I use 2 stroke oil you mix what gas.
gregrob is offline
post #10 of 296 (permalink) Old 07-27-2007, 03:48 AM
Re: 2 stroke oil
I've been using Stanadyne Performance Formula since buying a case about 3 years ago. I based that buying decision on writings by TheDieselStop forum participants who seemed to be the most experienced and knowledgeable. My notes from that research indicate typical users estimated about 0.5 increased mpg. That's so far from this 2 mpg claimed observation that dual-tank mpg-meter-equipped truck owners shouldn't have a tough time distinguishing between them.
Here's my suggested test procedure. Fill front and rear tanks with the same pump's diesel but the different additives in their suggested additive/fuel ratios. Switch dash-mounted fuel-tank-selector switch between front and rear tanks. Set cruise control on a long, flat, windless Interstate highway. Do not change cruise control until test observations are complete. After a few A-B comparison tests constant cruise control on level highway, consistent read-out values should emerge for each comparison mix. Wait until 5 miles have been run after switching tanks to allow sufficient flow to remove the other mix before recording current instant mpg meter values.
Do I trust Ford overhead MPG meter accuracy? No. But that's not at issue here. What's at issue is consistency. Factory overhead meters can display differences sufficiently well to leave no doubt about significant mpg differences.
Aside from mpg gains, I KNOW from experience that Stanadyne Performance Formula can restore some marginally operating single-shot injectors to good performing condition.
John
LoveLearn is offline
