Adrenaline HPOP Mileage increase? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 04-28-2009, 12:45 AM Thread Starter
Has anyone had look with this pump and fuel mileage increases? If so what have you seen?
OhioRiverCigarette is offline
post #2 of 6 (permalink) Old 04-28-2009, 10:21 AM
SD26's Avatar
Re: Adrenaline HPOP Mileage increase?
I would like to get one. They have only been available for maybe 60 days. Talk is 2MPG when towing, but I haven't seen an actual log.
Dave
2005 E350 6.0PSD
2003 Excursion Limited 4WD 7.3PSD - Sold
1996 E350SD dually 7.3PSD - Gone!
2002 VW Jetta TDI - stock
2007 Escape Hybrid
1999 Kaw KLR650 - 17/42 gearing
SD26 is offline
post #3 of 6 (permalink) Old 04-29-2009, 05:16 PM
Pulling sled for hire
ParkerFly's Avatar
Someone posted on another site that they saw about a .5 mpg increase. It's going to vary from person to person, probably depending on how bad your injectors actually need the extra oil pressure.
Justin
Justin
#62
'97 F-250 - 255k
463 hp - 7-9-09
BDP/Casserly Stage 2's, Mod H2E, Stealth Stage 2, BDP fuel system, Comp 910s, 7.3 ic, live tuned by Jonathan @ BDP.
ParkerFly is offline
post #4 of 6 (permalink) Old 04-29-2009, 08:58 PM
SD26's Avatar
Originally Posted by ParkerFly View Post
...probably depending on how bad your injectors actually need the extra oil pressure.
Justin
It's not a pressure increase, it's a volume increase. That's something that makes the Adrenalin different.
Dave
2005 E350 6.0PSD
2007 Escape Hybrid
SD26 is offline
post #5 of 6 (permalink) Old 04-30-2009, 12:50 AM
chris25151's Avatar
Yes, but if you run out of volume your pressure drops and the pressure is what makes sure it all gets in there and atomized correctly. The main reason for bigger HPOP's is because as your RPM or injector plunger volume increases your will not have enough volume to keep up the pressure. So volume = pressure in this instance.
'02 F-350 4x4 Crew Long - 4" lift on 35" Toyo's. Traction Bars, AGR Rock Ram, Air Bags w/ auto level. BTS 4r100 Tranny with PCS TCU powered by '03 Cummins CR w/ ARP 625's, Flux-2 Inj., Helix 2 Cam & Springs, PDI Exh Man., Garrett Stage 2 over S400 #1717-02 turbo, Smarty, Ind. Inj. Twin CP3, Air Dog Raptor 150 Fuel Pump.
chris25151 is offline
post #6 of 6 (permalink) Old 04-30-2009, 01:16 AM
SD26's Avatar
Not as I understand it. If you have questions, probably good to talk to Bob Riley.
Dave
2005 E350 6.0PSD
2007 Escape Hybrid
SD26 is offline
