mpg's - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 04-23-2009, 05:06 AM Thread Starter
StroKer01's Avatar
mpg's
HEY, Guy i have an 01 six speed .3.73 gears six inch lift edge evo. How many mpgs should i get if im not in it all the time?
TO MUCH FORD POWER!
2002 chevy Dmax PPE hot+2
1995 Power stroke .SD swap
Rangers lead the way
StroKer01 is offline
post #2 of 12 (permalink) Old 04-23-2009, 07:14 AM
secondarychaos's Avatar
Re: mpg's
If you're not in it all the time, you could do 17-18.
the edge will allow alot more fuel, so cautious driving requires more caution.
With alot of learning about how to drive for more economy, I could see you getting 22-24. Six speeds are saweet for that.
Dan
96 Powerstroke: 6637, downpipe to dump exhaust, 140v IDM and a shift kit.
84 Honda Sabre V65 1100: pipes, jet kit and new tires. Faster than I think I'll ever need.
secondarychaos is offline
post #3 of 12 (permalink) Old 04-23-2009, 04:18 PM
Re: mpg's
Not with 6 inch lift and probably 36 or 37 inch tires.
2006 Dodge 2500 MegaCab, 4x4, Auto, 5.9L CTD
SOLD-2001 F250 Lariat CC SB 4x4 auto, 207,000 miles, linex, DP tuner 40T, 80E, 120R. 3.5 inch DP/4 inch exhaust. ATS housing. AFE stage 1, Hutch and Harpooned, HV IDM. V-10 transmission cooler. Medium build transmission. Baby terminator single HPOP, Turbomaster wastegate, 1.0 exhaust housing.
tch.280 is offline
post #4 of 12 (permalink) Old 04-23-2009, 05:27 PM Thread Starter
StroKer01's Avatar
Re: mpg's
Yep im pushing 37's on 18''rims
TO MUCH FORD POWER!
post #5 of 12 (permalink) Old 04-28-2009, 02:32 AM
Deputydog's Avatar
Re: mpg's
14-15 Mpg
Deputydog is offline
post #6 of 12 (permalink) Old 05-01-2009, 04:37 PM
Custom Trailer Sales
TrailerHauler's Avatar
Re: mpg's
I would say anywhere around 16-18 with the six speed, its nice for fuel mileage. Just shift before 2k rpms even before 1900, and don't let any of the coal roll from your exhaust.
1999.5 F350 PSD CC Dually 05' Conversion
Stage I's - Gearhead Tuning - BTS - PCS
F550 rear suspension
1999.5 F350 PSD S/C 6spd Dually
R.I.P. Will Iott - "This ain't no practice run"
TrailerHauler is offline
post #7 of 12 (permalink) Old 05-01-2009, 04:53 PM
mimetic's Avatar
Re: mpg's
I'm gonna go ahead and sneak in here and ask a question...
The truck in my sig gets like 15.7mpg ALL THE TIME (HWY or city driving)
I don't think i have ever seen 18MPG what could be some reasons for low MPG?
I have had new air filter, fuel filter, cleaned Exhaust backpressure sensor....
Allen
2002 F250 Auto 2WD
4" exhaust, Gearhead Automotive Performance Tunes, Adrenaline HPOP, 3G Pod (PSI, Trans, Pyro), AIH Delete, S.S. HPX Line, Precision TC BD Valve Body, AFE Stage 1, Bellowed pipes, WW
mimetic is offline
post #8 of 12 (permalink) Old 05-02-2009, 12:29 AM
Re: mpg's
Leak in the up pipes, and boost leaks are the most common and easiest to check
post #9 of 12 (permalink) Old 05-02-2009, 03:27 AM
Re: mpg's
I have an 02 six speed with 3.73 rear and just x-springs. I get 19-19.5 at 70 mph on the highway. That is with driving very cautiously for mpg. I also have a cap with a slight bump. So I would think the estimates of 15-16 are probably accurate.
2002 f-350 PSD, 4x4, cc short bed, 6spd, ccv mod, airdog, AIS filter, isspro ev and scangauges, detroit TT, ITP boost annihalator, ITP RR, bellowed up-pipes, ats housing, turbomaster, 3.5 dp magnaflow, very happy with ultra smooth and linear PHP 50t, 80DD and "whisper" tunes.
clydesdale is offline
post #10 of 12 (permalink) Old 05-07-2009, 03:22 PM
Big dumb redneck
6speedSD's Avatar
Garage
Re: mpg's
I used to have a 2000 2wd with the 6 speed, and I got 20-21 consistently, unless I was towing. Had intake, magnaflow muff, and superchips programmer. I know you are a 4x4 with lift/tires, but gives you something to go off of.
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
