Check 'Em Again Boys - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 12-02-2013, 05:47 PM Thread Starter
MPG Moderator
Dave Whitmer's Avatar
Your brakes that is.
One of the annoyances of driving a Powerstroke is that the things have enough torque to drive OK with a brake or two dragging and not be noticeable.
My MPG dropped off and I checked but it was too late. I had cooked a rotor.
Apparently when the weather is cooler the caliper pin galls and the brakes stick just a little.
When my truck dropped to 19 MPG I knew something was wrong.
2000 F-350 SC 4x2 6 speed
Slammed 4"
Rugged Air Dam
315,000 miles
Dave Whitmer is offline
post #2 of 6 (permalink) Old 12-06-2013, 06:23 AM
Sick Sixo
mysixoissick's Avatar
Re: Check 'Em Again Boys
My mpg just dropped from 12 to 8, how do you check for brakes dragging? I really need to know asap!
mysixoissick is offline
post #3 of 6 (permalink) Old 12-06-2013, 12:15 PM
BIG BLU's Avatar
Jack the truck up and try to spin each wheel, if you cannot spin them by hand then you have a issue.
05' 6.oh yeah, CCSB, 4x4, medium wedge wood blue, studded, 03' turbo with Barder billet wheel, BPD external oil cooler, BPD egr cooler, BPD water pump, BPD 58v ficm, BPD aluminum radiator, OEM updated everything, fluidampr, 6.4 banjo's, blue spring kit, riff raff boots, 5" diamond eye exhaust no muff no kitty, 6" icon lift on toyo 325/70/17's.
BIG BLU is offline
post #4 of 6 (permalink) Old 12-12-2013, 08:09 PM
It's much more subtle. A brake can be dragging and still be spinnable by hand. Listen for the swoosh of a brake pad only touching the rotor once per revolution. That's what you want. Not a steady drag.
Or, just pop off each pin and lube it eavery time you rotate the tires. The pins are very easy to access.
2000 F350 SRW, 4wd, CCSB, PSD
Lowered rear end to F250 height, 4" exhaust w/ muff, foil delete, AIH delete, Ford AIS intake, tru-cool trans cooler, autometer under dash pod and gauges, Mile Marker hubs, 04 headlights, soft tonneau
18' 10k rated PJ car hauler
26' 7500# Creekside RV Trailer
Kioti CK30 tractor
Highbeam is offline
post #5 of 6 (permalink) Old 12-16-2013, 07:24 PM
MrOneEyedBoh's Avatar
You cna use an infrared/laser thermometer and read wheel temps. Thats usually only in extreme cases. But still if you have one that is 50-100deg different than the other three, its a pretty good chance thats it.
MrOneEyedBoh is offline
post #6 of 6 (permalink) Old 12-17-2013, 03:17 PM
Sick Sixo
Rear ones too
