Blue CPS - how does it affect economy? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 07-26-2007, 03:00 AM Thread Starter
gregrob's Avatar
Has anyone tried the blue CPS for economy reasons?
It supposedly retards timing, and if that's the case may actually hurt economy, but I haven't actually tried it.
Who has?
gregrob is offline
post #2 of 9 (permalink) Old 07-26-2007, 11:46 PM Thread Starter
gregrob's Avatar
Re: Blue CPS - how does it affect economy?
ttt, I know some of you are running the blue one...
Out with it!
gregrob is offline
post #3 of 9 (permalink) Old 07-27-2007, 05:30 AM
Starting Over
kainers's Avatar
Honestly there isn't one damn thing that has ever really helped economy wise.I think it is more a placebo like not stomping on it as much and baby the throttle.Doing that I always get better fuel mileage but what the hell is the point to add a part then drive it easy.
It did quiet down and got rid of a miss I had with the new Grey CPS the 20 dollar one that JSM1 hooked me up with.
kainers is offline
post #4 of 9 (permalink) Old 07-27-2007, 10:34 AM
Don't EFN worry about it
Aljay's Avatar
When I had the blue sensor in my truck it was real smokey. I finally put the black sensor back in and the truck was less smokey and seemed to get better fuel milage.
Tuned by T Wildman
Aljay is offline
post #5 of 9 (permalink) Old 07-27-2007, 03:10 PM
MPG Moderator
Dave Whitmer's Avatar
I would think a blue CPS would indeed hurt MPG. Anything that retards injection will give the fuel less time to completely burn means you need more fuel next combustion event.
Yeah, I'm sure the blue CPS quiets her down. Retarded injection will do that. The most efficient engine is the one rattling like crazy at low RPM.
2000 F-350 SC 4x2 6 speed
Slammed 4"
Rugged Air Dam
315,000 miles
Dave Whitmer is offline
post #6 of 9 (permalink) Old 07-31-2007, 06:44 AM
utah get me two
wish i knew....bought truck....changed out cps next day....at the time i didnt know there were 2 ...thought they just used different plactic.....i run dp chip at 80 tow and have 35s.....dynowed at 275 hp......if that helps.....david
[SIGPIC][/SIGPIC]2001 f250 4x4 cc sb 6 in lift...dp 6 pos..
glamis_dave is offline
post #7 of 9 (permalink) Old 07-31-2007, 09:20 PM
<----Colin Banks
mattymx's Avatar
Now isnt that why the higher HP settings on most chips give the best MPG under normal-EZ driving because they are "ADVANCING" the timing? But then again WTFDIK...
mattymx is offline
post #8 of 9 (permalink) Old 08-01-2007, 03:41 AM
BLCKOUT
bigcountry250's Avatar
Send a message via AIM to bigcountry250
I have also been wondering about the Blue CPS and what kind of advantages it gives you, like mpg, performance, etc.?
2011 CC SB 6.7L Powerstroke
BLACKOUT.... gone but never forgotten!!
bigcountry250 is offline
post #9 of 9 (permalink) Old 08-12-2007, 05:29 AM
OBS junkie
Cat_Rebel's Avatar
We ran one for a few months back before we had a chip. When you hammered it, it would put out a slight gray haze. Even with a straight pipe it just seemed like something was holding it back. The blue one will turn it into more of a dog. I don't know what affect it had on the MPG. The thing that really made us ditch it for another black one was when winter came around. When it got cold & it was below freezing , it would go into the whole "Hi-Idle & Exhaust back pressure valve thing". But it would stay there for a long time without much affect. Installed the black one & worked like it's supposted to. Retarding you timing in subzero temps on a cold Diesel isn't the best idea.
Still have it for a spare, that's just what I think of them now. I'd only install one in an event that a black one failed.
Kinda wonder what would happen if you had one & put a DP Tuner on Lope Idle...?
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
