Driving Tip: Acceleration - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 10-02-2013, 06:33 PM Thread Starter
MPG Moderator
Dave Whitmer's Avatar
Some tests have been done on automatic transmission vehicles, concerning how hard you accelerate vs MPG.
Turns out that for legs of over a mile, it makes little difference in overall MPG how hard you accelerate. Yeah, accelerating very slowly (think granny in a M-B 240D) garners you a whopping 0.1% better MPG.
Best to accelerate fairly hard (as long as upshifts are not delayed) up to cruising speed in top gear then steady out on your cruise speed.
This keeps the engine in its sweet high load/low RPM mode all the way up to cruise speed, then you level out at your desired speed.
This advice should work for a stick as long as you don't shift at a higher RPM.
2000 F-350 SC 4x2 6 speed
Slammed 4"
Rugged Air Dam
315,000 miles
Dave Whitmer is offline
post #2 of 3 (permalink) Old 10-02-2013, 11:53 PM
Re: Driving Tip: Acceleration
I agree..... My auto Ex gets best in OD, and especially when going up a long hill it's best to get there a bit faster.
DieselX is offline
post #3 of 3 (permalink) Old 10-04-2013, 03:34 PM
SD26's Avatar
Originally Posted by Dave Whitmer View Post
Some tests have been done on automatic transmission vehicles, concerning how hard you accelerate vs MPG.hould work for a stick as long as you don't shift at a higher RPM.
Hey, Dave, do you have a link to some of those tests?
I've been experimenting with my Scangauge in my Jetta using the LOD gauge. Bettered my MPG very consistently. My van is down right now, so I can't currently translate that data back to the auto in it.
Dave
2005 E350 6.0PSD
2003 Excursion Limited 4WD 7.3PSD - Sold
1996 E350SD dually 7.3PSD - Gone!
2002 VW Jetta TDI - stock
2007 Escape Hybrid
1999 Kaw KLR650 - 17/42 gearing
SD26 is offline
