Heat or Revolutions? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 23 (permalink) Old 01-14-2009, 05:17 PM Thread Starter
Peon Extraordinaire
So my question is fairly simple. Which one hurts mileage more EGT or RPM? I drive 37 miles one way to work and am able to cruis for 20ish miles at 50-60MPH. I have noticed that doing 55 in overdrive my egt's sneak up above 600 sometimes up around 900. I will be cruising at 1500 RPM. I can lock the OD out and my EGT's drop to ~450 but my RPMs jump to ~2300.
So which is better:
the low EGTs with higher RPMs
Low RPMs with Higher EGTs?
Sam
genie144 is offline
post #2 of 23 (permalink) Old 01-14-2009, 05:36 PM
Lovin the Tuna
RedSmokey's Avatar
Re: Heat or Revolutions?
I am curious about that myself...
2001 F250
2000 F250
RedSmokey is offline
post #3 of 23 (permalink) Old 01-14-2009, 05:46 PM
secondarychaos's Avatar
IMO if you're driving light, Rpms should make a bigger difference.
I base this on No scientific data, comparison or thought. Just an opinion.
Dan
96 Powerstroke: 6637, downpipe to dump exhaust, 140v IDM and a shift kit.
84 Honda Sabre V65 1100: pipes, jet kit and new tires. Faster than I think I'll ever need.
secondarychaos is offline
post #4 of 23 (permalink) Old 01-15-2009, 01:04 PM
SD26's Avatar
Yeah, personally, I'd feel that higher RPM's are going to hurt.
I feel that way for a couple of reasons. First, friction. Second, the aerodynamics of moving parts. I would think that those items increase exponentially as RPM's go up.
Dave
2005 E350 6.0PSD
2003 Excursion Limited 4WD 7.3PSD - Sold
1996 E350SD dually 7.3PSD - Gone!
2002 VW Jetta TDI - stock
2007 Escape Hybrid
1999 Kaw KLR650 - 17/42 gearing
SD26 is offline
post #5 of 23 (permalink) Old 01-16-2009, 10:55 PM
MPG Moderator
Dave Whitmer's Avatar
Genie144:
Why don't you do a test and tell us?
A couple of tankfuls with low RPM/high EGT note the MPG.
A couple of tankfuls with high RPM/low EGT note the MPG.
Not a tough test to do. Enlighten the masses.
2000 F-350 SC 4x2 6 speed
Slammed 4"
Rugged Air Dam
315,000 miles
Dave Whitmer is offline
post #6 of 23 (permalink) Old 01-16-2009, 11:02 PM
sounds like a good idea to me.
But you need a baseline first...
Dan
post #7 of 23 (permalink) Old 01-17-2009, 05:42 PM
MPG Moderator
Yup. Two weeks baseline. That also gives you a chance4 to standardize your driving.
Then two weeks one way (high RPM/low EGT)
Then two weeks the other way.
Don't sweat the fact it is winter. The percentage change is what you are looking for. Maybe repeat in mid-summer.
Slammed 4"
Rugged Air Dam
315,000 miles
post #8 of 23 (permalink) Old 01-18-2009, 05:48 AM
as long as all the tests are done on winter fuel, it won't matter...
Dan
post #9 of 23 (permalink) Old 01-19-2009, 03:17 PM Thread Starter
Peon Extraordinaire
Dave
Normally I would do the testing and report. A single tank load each way (100 gallons). But I won't be able to perform the testing for a month or two. I have some things I am tweaking with my fuel system that would make it impossible to establish an accurate baseline. Not to mention the validity of any data would be suspect with the change of fuel pump and additional filtration in the middle of it.
I was curious if anyone had done the testing - I know you always say keep heat down and RPMs low. I can see an argument for each being more important.
As soon as I get the fuel system locked up I will do the testing.
Sam
On edit - not to mention that my fuel additive choice (SVO) makes my truck less than an ideal test bed for the masses
genie144 is offline
post #10 of 23 (permalink) Old 01-21-2009, 09:45 PM
Junior Mint
If it's not hilly run in OD for the best mpg in this case.
EGTs are higher but that is a function of less boost, not more fuel being used as you might have suspected.
I'm officially...Stroke-less.
Suns_PSD is offline
