203 stat and 235/85 tires - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 10-11-2007, 01:52 PM Thread Starter
I currently have the 203 stat for a few years and I thought that it did help with economy, but I have had my doubts over the years. What have you guys discovered about this mod? Also, I am getting close to the end of my stock tires. Does it help to go to the narrower 235s? Thanks
2002 f-350 PSD, 4x4, cc short bed, 6spd, ccv mod, airdog, AIS filter, isspro ev and scangauges, detroit TT, ITP boost annihalator, ITP RR, bellowed up-pipes, ats housing, turbomaster, 3.5 dp magnaflow, very happy with ultra smooth and linear PHP 50t, 80DD and "whisper" tunes.
clydesdale is offline
post #2 of 4 (permalink) Old 10-12-2007, 12:30 AM
MPG Moderator
Dave Whitmer's Avatar
Re: 203 stat and 235/85 tires
I put the 203 degree stat on my truck and documented an 0.5 MPG improvement.
I really think these engines are pretty optimized but put inot wildly overgeared drive trains. I don't think there is much fuel economy improvements to be had from tinkering with the engine. Even with a specail MPG chip, I got only a 0.75 MPG improvement.
As for tires...in theory the 235-85s should give better MPG than the 265-75s but I've had both and can't document any difference. be sure to get E rated tires and air them up to 80 psi.
I may be doing new tires in the spring and I think I'm gonna try some rib-pattern tires like the Michelin XPS Rib.
2000 F-350 SC 4x2 6 speed
Slammed 4"
Rugged Air Dam
315,000 miles
Dave Whitmer is offline
post #3 of 4 (permalink) Old 10-12-2007, 12:59 AM
txpsdcrwchf's Avatar
Send a message via Yahoo to txpsdcrwchf
yea i agree i dont see a whole lot of MPG gain I run 285-75-16 and i dont notice a drop from the 245-65 i was running. with your 4wd id stick with the larger tire. It kinda defeats the purpose of having the 4wd and wont look as good on your truck.
Jeff
HIS: EARLY '99 F250 SD 4x4 Off Road, 7.3L PSD 6 SPD SuperCab Short Bed
DP Tuned (F5) NS, S, 40T, 80E,
HPx Line-DIY Tymar-Fuel System(on Return)
HERS: '99 DODGE Ram 2500 4x4 5.9l I6 Cummins 6SPD QuadCab Shortbed
Edge ez 20, 40, 60:
txpsdcrwchf is offline
post #4 of 4 (permalink) Old 10-12-2007, 11:47 PM
MPG Moderator
Going from 245s to 285s would in fact decrease your fuel mileage.
Slammed 4"
Rugged Air Dam
315,000 miles
