6.5 mpg towing???? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 01-11-2009, 11:56 PM Thread Starter
suprdzlduty's Avatar
6.5 mpg towing????
I have a 01 350 CC dually 4x2 w/4.10 gears that we use to pull a 40' gooseneck. The truck has a superchips tuner on the low setting (i know its not the best), air intake, 4" exhaust, and gauges. Sometimes we haul 2 F-550's (cab and chassis) at a time or just one. I have never been able to get above 7 to 8 mpg loaded or unloaded and most of the time its 6.5 mpg. What is wrong with this truck i know it can do better. I dont run flat footed either 60 mph tops. Any help would be great, my dad gets better mpg with his 379 Pete!
suprdzlduty is offline
post #2 of 5 (permalink) Old 01-12-2009, 12:10 AM
That thing got a Cummins?
nasty96's Avatar
Re: 6.5 mpg towing????
It sounds like you are running that truck way overloaded,and if by empty you mean the trailer is behind it but nothings on it, you still have alot of wieght/drag to overcome. The biggest reason the pete gets better mileage is you have more gears,torque and horsepower to move the same amount of wieght. I think you just ask to much of the truck to get decent mileage pulling that kind of wieght. Just my .02
Ford makes it
, I break it
1996 F350 CCLB 4x4 Broke Built Auto
2000 Dodge 3500 5 Speed 4x4 450k and Counting
2001 Dodge 3500 6 speed 4x4 Fully loaded
nasty96 is offline
post #3 of 5 (permalink) Old 01-12-2009, 12:12 AM
I have gotten anywhere from 6.0 to 20 mpg. I haul a 25ft trailer with 13 atvs standing on end and with the hills and the wind I have to stop between 150 and 180 miles and fill up. I dont think theres anything wrong with my truck you can just tell your working it. I weighed my truck with the atvs and trailer it it was about 20000. I run 70-80 on avg. I could slow down and not work my truck I bet I would get a bunch more out of my tank. I dont believe what people tell me the get for mpg. I just know running emepty with a trailer I can get better than a gas power truck and thats what matters to me.
2011 6.7 F350 CCSB BLUE SWEET RIDE
1996 F350 BABY SWAMPS AND TS, FLAT DOWNPIPE
semomotorsports is offline
post #4 of 5 (permalink) Old 01-12-2009, 03:55 PM
secondarychaos's Avatar
Do you have a boost gauge on it?
I don't see how you could get that bad of mileage towing.
FWIW, I towed a 22ft car trailer with my toyota rockcrawler (in the works) and a pair of atv's and averaged 14.
I'd start by upping tire pressure, (assuming it's auto) doing a shift kit, and checking for boost or exhaust leaks. maybe check the turbo for shaft play...
just throwing these out there, but they can only help and checking's free.
Dan
96 Powerstroke: 6637, downpipe to dump exhaust, 140v IDM and a shift kit.
84 Honda Sabre V65 1100: pipes, jet kit and new tires. Faster than I think I'll ever need.
secondarychaos is offline
post #5 of 5 (permalink) Old 01-12-2009, 04:34 PM
Power by IH
Stroked550's Avatar
Send a message via Yahoo to Stroked550
Loaded with the trailer and 2- F-550's you have to be around 30k gross. I average around 7-8mpg loaded to 40k gross, depending on the terrain, but thats with 4.88's and Jody's 60 or 80 tow tune. The worst I've ever gotten was 6, but that was pulling the GN with a 680 Case backhoe from NJ back to OH through some nice hills. I'd try Jody's 40hp tow tune to start and work from there.
2000 F-550 CC, 2wd, 6 speed. Homemade bed, 5" exhaust, DP chip, water inj, intake, gauges, ect
Stroked550 is offline
