Average MPG 11.2 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 01-09-2009, 05:30 PM Thread Starter
antibullock's Avatar
Average MPG 11.2
my truck calculates my average MPG for me on the dash and it says I'm only getting 11.2 MPG can I trust the reading or is it probably inaccurate. thanks
2005 Ford F-250, Airaid intake, Mickey Thompson Baja MTZs 315 70r17 , 2.5 inch leveling kit, 6.0L, Quadzilla Adreneline w/ PCM, Killed the Kitty, 6inch dual aussie stacks. (soon to be installed) Barefoot gas pedal
2002 Honda civic (totaled) daily driver, stock
antibullock is offline
post #2 of 15 (permalink) Old 01-09-2009, 05:42 PM
Re: Average MPG 11.2
Its called a Lie-o-Meter. Mine has never been right even when on the stock tune.
Take a trip and hand calculate it.
Harohunter is offline
post #3 of 15 (permalink) Old 01-09-2009, 10:28 PM
secondarychaos's Avatar
yep. hand calculate is the only way.
FWIW, my buddie's 6.0 said he was getting 23... hand calculated he was getting 14.9...
Dan
96 Powerstroke: 6637, downpipe to dump exhaust, 140v IDM and a shift kit.
84 Honda Sabre V65 1100: pipes, jet kit and new tires. Faster than I think I'll ever need.
secondarychaos is offline
post #4 of 15 (permalink) Old 01-10-2009, 12:17 PM
SD26's Avatar
And your signature states 35's. Might want to check your speedometer against GPS just to see what your actual MPH is. Even if it was change, it's still worth checking so that it is eliminated from possible and reasonable error.
Dave
2005 E350 6.0PSD
2003 Excursion Limited 4WD 7.3PSD - Sold
1996 E350SD dually 7.3PSD - Gone!
2002 VW Jetta TDI - stock
2007 Escape Hybrid
1999 Kaw KLR650 - 17/42 gearing
SD26 is offline
post #5 of 15 (permalink) Old 01-10-2009, 02:20 PM
Village Idiot
LRTMatt's Avatar
My 06 is very accurate both stock and tuned. It's always within 2 or 3 tenths every time. In order for it to be accurate you have to reset it at fill up and not touch it again until you fill up the next time. You also have to fill the tank to a consistent level every time. If I don't fill to the same level, I can see some wide discrepencies between the hand calc and the meter.
35s are going to make a difference if your speedometer hasn't been calibrated for them, but it should make the mpg on the meter look worse not better.
LRTMatt is offline
post #6 of 15 (permalink) Old 01-10-2009, 06:02 PM
That thing got a Cummins?
nasty96's Avatar
Your tires may be thowing off you odometer, and showing less miles than you drove. That would through fuel mileage way off, done by hand or the trucks computer. Check the accuracy of the odometer. Mine is off by .2 miles with 35's
Ford makes it
, I break it
1996 F350 CCLB 4x4 Broke Built Auto
2000 Dodge 3500 5 Speed 4x4 450k and Counting
2001 Dodge 3500 6 speed 4x4 Fully loaded
nasty96 is offline
post #7 of 15 (permalink) Old 01-10-2009, 06:47 PM
OBS junkie
Cat_Rebel's Avatar
Have you been doing alot of driving in 4x4 & in the snow? I know that will cut down MPG like nothing else + winter fuel & the weather being colder.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #8 of 15 (permalink) Old 01-12-2009, 01:34 PM Thread Starter
No I havnt used 4x4 at all. It hasn't really snowed where I am yet. I'm not towing or anything either. So I guess its wrong. I'll check if my speedometer is calibrated and let you guys no.
post #9 of 15 (permalink) Old 01-12-2009, 05:40 PM
unless the truck came with 35's i have to assume the speedometer is not correct
there are a few ways to fix that issue.
mostly i suggest inline devices, as I have yet to hear of somebody with a programmer correct their speedometer, unless they get it done by ford, and even then they can only go to 35" tires i think
kenny
Mercury is offline
post #10 of 15 (permalink) Old 01-12-2009, 09:41 PM Thread Starter
kenny
I am also going to assume the speedometer is incorrect because I bought the truck used and the guy had 35s on it so there is a very good chance that it is incorrect.
