cracked intercooler hoses killing mpg - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 12-22-2008, 06:48 PM Thread Starter
Angry cracked intercooler hoses killing mpg
ok heres the prblm i have i was looking at my intercooler hoses an every1 of them has about a inch long crack in them im going to replace them but could this be why i cant get past 14 mpg wit my truck running it hard or babing it an thats running my dp on 80 eco?
1999 ford super duty ex cab short bed 4x4 dp-tuner f-5 lomp mod,80 econ,100,120 race,140 aggresive 4inch exaust to 6-inch tip non-wastegated housing upgrade from bts di-performance crossover line di-performance fuel tank mixing delete autometer gauges boost,trans,pyro custom made cold air intake.
big bad stroker is offline
post #2 of 7 (permalink) Old 12-22-2008, 10:39 PM
Re: cracked intercooler hoses killing mpg
Yes that can cause mileage problems. You are losing boost, so you step on the gas pedal harder........................which uses more fuel. I had a friend with the same problem, so this is how I know.
2001 F-350 CC Drw, GT-4294/1.01, 200cc splits, AFE stage 2, custom fuel system, Rickson 19.5's, many more mods.
outlaw5.0 is offline
post #3 of 7 (permalink) Old 12-22-2008, 10:47 PM
MPG Moderator
Dave Whitmer's Avatar
Easy way to tell. Are you smoking? If so, you need more air. If not, don't worry about it.
Since you have gauges, I assume you have a pyrometer. Keep the EGT (pre) below 600 and your RPM below 2000, and your MPG will improve.
2000 F-350 SC 4x2 6 speed
Slammed 4"
Rugged Air Dam
315,000 miles
Dave Whitmer is offline
post #4 of 7 (permalink) Old 12-23-2008, 04:03 PM Thread Starter
yeah its bad smokey even on my 80 eco it roles black alot of black if im going down the highway at 60 mph an punch it i will cover the car up behind me lol.
post #5 of 7 (permalink) Old 12-24-2008, 12:49 AM
WV Smoker
P714's Avatar
If you want some cheap but durable replacement boots go to a tractor trailer supply place and ask for 3" radiator hose. They'll cut to length most places. This stuff is pretty tough, probably about 3/16" thick. If you have an intercooler that can be a little tough because those ends are around 3.5", I think. There, just heat them up and use some soapy water and slide them on. That's all I use and have had them up to around 55psi no problem.
I believe www.dieselsite.com has a leakdown tester if you want to be sure first.
Zack
early '99 F-350 reg. cab 6-speed 106,000 miles
P714 is offline
post #6 of 7 (permalink) Old 12-25-2008, 05:10 PM Thread Starter
ok cool i might try them i need somthing an im not going back with the factory ones lol.
post #7 of 7 (permalink) Old 01-03-2009, 10:43 PM
What else?
smokyred's Avatar
If the originals lasted 10 years, I doubt you'll have a problem getting new factory boots to work another 10 years. Do you think you'll even still have the truck then?
Dave
smokyred is offline
