MPG with WMO - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 12-19-2008, 11:34 PM Thread Starter
MPG with WMO
When using WMO at a 50/50 ratio with diesel would ICP need to be increased for max. MPG due to lower viscosity? Today outside temps were up to 75 degrees and the truck had lots more response to the throttle compared to 20-40 degree temps of the last week or so. It would appear to me that more ICP would be better in this situation.
99.5 F-350 SRW 6 speed mods:PHP live tuned., MSD propane system, snow water injection,DDP stage 1 injectors,AFE stage II air intake,ITP boost regulater,3.5 turbo back exaust,FASS fuel system. Gulf Coast oil bypass filtration, ITP reg. return, HPX oil line , GTP 38r with 1.15,EBPV delete. 430,000 miles,Adrenaline HPOP
cantrellc123 is offline
post #2 of 4 (permalink) Old 12-20-2008, 12:23 AM
MPG Moderator
Dave Whitmer's Avatar
Re: MPG with WMO
Seems to me WMO would be MORE viscous at low temps.
Higher ICP might help up to a point. That point is where the WMO cannot flow into the injector fast enough to fill it before the high ICP squirts it in.
I would think at relatively lower temps a splash of kerosene might reduce viscosity enough to fill the injector.
Another possibility is to reduce RPM enough that more viscous fuel can fill the injector.
2000 F-350 SC 4x2 6 speed
Slammed 4"
Rugged Air Dam
315,000 miles
Dave Whitmer is offline
post #3 of 4 (permalink) Old 12-20-2008, 09:25 PM Thread Starter
Re: MPG with WMO
Thanks for the input Dave,sorry about the poor wording of the question. I will try some kerosene at next fill up. How much kerosene would be needed on a 35 gallon fill up? The temps here rarely drop below 20 degrees overnight. RPMs are probably not an issue as I seldom go over 2500 RPM unless clowning around a little bit.
post #4 of 4 (permalink) Old 12-20-2008, 09:56 PM
MPG Moderator
Re: MPG with WMO
For that far south, 2 or 3 gallons per full tank should do fine. I use 5 per tankful on the frozen steppes in winter.
Slammed 4"
Rugged Air Dam
315,000 miles
