6.0 mileage increases..... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 21 (permalink) Old 04-21-2013, 04:12 PM Thread Starter
ive got a 2004 F250 4x4 6.0. its currently a daily driver, ive got an AEM cold air intake, mbrp 4in exhaust, SCT Livewire TS. ive got a sinister egr delete just havent got it on yet. but is there anything in particular that can help boost me up past this 15.5 AVG MPG mark? itd b nice if they just started givin diesel out so i wouldnt have to complain ha
Scolesy8 is offline
post #2 of 21 (permalink) Old 04-21-2013, 04:26 PM
6.4L believer
08straightpiped's Avatar
Re: 6.0 mileage increases.....
Yeah you bet trade it in on a Toyota Camry it's an 8000lb truck
2007 F-350 Crew Cab Harley Edition LWB
2008 F-350 Crew Cab 4X4 "SOLD"
H&S Performance Mini Max
KEM Tuned
4" Straight piped downpipe back dpf and cat gone
pro comp extreme a/t's
08straightpiped is offline
post #3 of 21 (permalink) Old 04-21-2013, 10:48 PM Thread Starter
ha noooo..... i'll stick with this before i get a toyota ha
Scolesy8 is offline
post #4 of 21 (permalink) Old 04-22-2013, 12:20 AM
Put an egg behind the gas pedal and try not to break it.
Let it eat!
04 F250 Crew Cab Harley Edition. MBRP 5" exhaust, ARP studs, sinister delete, mkm complete solution, blue spring, updated stand pipe, banjos, sinister coolant filter, Innovative 58v FICM, SCT Livewire TS with tunes from MPT, more to come!
Cfletcher93 is offline
post #5 of 21 (permalink) Old 04-22-2013, 12:56 PM
SD26's Avatar
Yeah, that is a method, Cfletcher. Welcome to the forum!
Scolesy8, what's your gear ratio?
Dave
2005 E350 6.0PSD
2003 Excursion Limited 4WD 7.3PSD - Sold
1996 E350SD dually 7.3PSD - Gone!
2002 VW Jetta TDI - stock
2007 Escape Hybrid
1999 Kaw KLR650 - 17/42 gearing
SD26 is offline
post #6 of 21 (permalink) Old 04-22-2013, 04:54 PM
40 lug nuts
Snake's Avatar
BULLETPROOF DIESEL
Biofuels Technologies
1A Auto
2005 F-250
Snake is offline
post #7 of 21 (permalink) Old 04-22-2013, 11:04 PM
Bigdog's Avatar
16.5 to 17 mpg average hand calculated hwy/city and I don't think it's that bad! It improved quit a bit when I hit the 200,000 km (125K mile) mark.
2012 F350 Lariat Crew Cab 4X4
EGR & DPF Delete
55 Gal Titan Fuel Tank
2004 F 350 XLT Crew Cab 4X4 SRW 6.0 with a lot of Upgrades. (Sold)
2008 F 350 King Ranch, S&B Cold Air Intake, SCT Extreme with DPF Delete Kit (Sold)
1998 Dodge 2500 5.9 Cummins 12V
Bigdog is offline
post #8 of 21 (permalink) Old 04-23-2013, 01:59 AM Thread Starter
stock ratio. i wanna say 3.73 but dont quote me, i'll have to check it out ha. well, i imagine my new tires dont help it any, i just put on a set of 305/60R18 Dick Cepek fun country 2's. but does the EGR delete help with mileage at all? just wondering. if so i'll be sure to get on it quicker, just been short for time with farmin bein main priority
Scolesy8 is offline
post #9 of 21 (permalink) Old 04-23-2013, 08:41 AM
SD26's Avatar
Well...
My gas engined tow rig was getting 6.5 to 8MPG with its best being right around 8.5MPG. I went to a diesel rig, in a heavier chassis, and my MPG was 10.5 to 12MPG with some in the 15's.
For me, that was a way to reduce cost, even with the extra cost of diesel fuel and the additional oil required for oil changes... If I can spend less and do the same work, I'm looking for that efficiency to maintain as much money in my pocket or in the pocket of my business so that I can capitalize on other opportunities.
Dave
2005 E350 6.0PSD
2007 Escape Hybrid
SD26 is offline
post #10 of 21 (permalink) Old 04-23-2013, 09:01 AM
SD26's Avatar
I don't know on the EGR delete. Some say it does, others seem to not be concerned, and others seem to say no difference. I think that some tuners can be set to reduce the EGR once it has warmed up the coolant, which could be a good use of all the heat in the exhaust after start up when the engine is cold.
My current van has an average MPG of just under 19MPG. I've got the stock sized tires, and the rear gear ratio is 3:55...automatic transmission. I don't do a lot of hauling, and I don't use the van like I used my other vans. I bought this one well used...a survivor...with 398k. EGR did need to be replaced. Seems to run strong. I had two 7.3's before, and the 6.0 scared me, but I'm doing better now...at least I keep telling myself that.
At speeds just below 60MPH, I think the engine turns just under 1700RPM's. And at just below 70MPH, the engine R's are under 2000 yet, if I remember correctly from my drive home.
I've put on taller, wider tires on my one van, the bus, and, while it allowed me to reduce the engine RPM's at the same speed, I saw a reduction in my MPG. I figured that was the result of all, some, or one (or none) of the following: van became too tall and increased wind resistance, van was too tall and too much air was going under van that increased drag, larger tires had extra weight that took more power to move, larger tires had extra width that increased wind resistance.
If I'm going to make a change this time around, one might be in going to a narrower tire with the same diameter. The stock tire is a 245/75R16, and I'd consider a 215/85R16. Weight would be reduced, and width would be reduced while maintaining the current "as designed" gear ratio and overall height.
Considering ideas on building an air dam.
I enjoy the stuff made by DP Tuner. I think their programs has a little better shift strategy than stock strategies...seems like the OEM ones don't lock up the torque converter soon enough and they hold the RPM's out pretty high before shifting...my thoughts at least. A manual transmission would be ideal, but converting a van would be an expense that I don't want to tackle.
Dave
2005 E350 6.0PSD
2007 Escape Hybrid
SD26 is offline
