Split-Shot Injectors - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 31 (permalink) Old 10-18-2008, 05:21 PM Thread Starter
MPG Moderator
Dave Whitmer's Avatar
After about 4,500 miles of testing, I have come to a conclusion about single shots.
They do improve MPG - by about 1%.
I changed out my 218,000 mile splits for new singles from a top injector outfit. I got six different tunes as well Two of those were better than the rest.
With my old splits, I got 26.9 MPG summer mileage on my normal loops (35% urban, 35% two-lane road, 30% Interstate - all driven at posted limit or close as I can get). With the single-shots I averaged 27.3 with the two best tunes. I obviously have not tried them in winter yet.
I have not monkeyed with my aero package since starting the injector test.
Not a drop of additive of any sort has gone into the tank since starting the injector test.
Oddly enough a tune approximating a commercial performance tune did quite well once I changed my shift points. Normally I shift at 1200-1300 RPM. For his fangs-out MPG tune, this worked well, but for the performance tune it made my truck smoke like a steam locomotive. By shifting at 1800 RPM (high RPM for me) the turbo perked up and the smoke cleared. When all was said and done the two tunes gave with 0.02 MPG of each other. My margin of error is usually about 0.3 MPG.
Make of it what you will.
2000 F-350 SC 4x2 6 speed
Slammed 4"
Rugged Air Dam
315,000 miles
Dave Whitmer is offline
post #2 of 31 (permalink) Old 10-18-2008, 05:46 PM
Re: Split-Shot Injectors
i think you shoulod go one size up on the gears. let that turbo spool a little more. all you are doing is wasting fuel down low IMO. who tuned it and what injectors were they?
PMRCM#1
slowleak is offline
post #3 of 31 (permalink) Old 10-19-2008, 07:03 AM
You say at first splits give better economy and then you list mileage numbers that say your new single shots give better economy?
69W900A is offline
post #4 of 31 (permalink) Old 10-19-2008, 02:18 PM
matthewd11's Avatar
I noticed that earlier, but i wasnt going to be the first to say something
matthewd11 is offline
post #5 of 31 (permalink) Old 10-19-2008, 05:38 PM Thread Starter
MPG Moderator
My bad. Let's get it clear: Single shots give better MPG than split shots. That clear enough?
The fact that a fangs-out MPG tune and a more or less performance tune gave about the same MPG (although they require different driving techniques) leads me to the logical conclusion that the tune is irrelevant to MPG.
What I want no part of is a contest of commercial loyalty - "A's stuff is better than B's stuff."
Slammed 4"
Rugged Air Dam
315,000 miles
post #6 of 31 (permalink) Old 10-20-2008, 02:02 AM
Precision Planting Dealer
Deereman4020's Avatar
Man thats really incredible the mileage you are getting out of that truck. Keep up the good work.
1994 F-250 7.3L PSD reg cab long bed 5spd 4X4 6637, home brew stack and SD fuel system Jacob
Farming isn't a job or a hobby. It's a way of life. A way of life that no matter what, some people just can't let go. I'm one of those people. Those proud to be a reliable American farmer!!
PM me for precision planting parts.
Deereman4020 is offline
post #7 of 31 (permalink) Old 10-20-2008, 02:47 AM
2010 BOB Points Runner up
Dieselfever's Avatar
Send a message via AIM to Dieselfever Send a message via Yahoo to Dieselfever Send a message via Skype™ to Dieselfever
Good to hear Dave! So far you have picked up around .4 mpg so far.
I understand what you say about the comparison between the 'made for fuel economy' program and the performance program. I have similar results with the same scenario in my '95 between the 'all out power' program and 'made for fuel economy' program where they net about the same fuel economy. I guess that might be the nature of these beast even with the different tuners.
-Michael
Michael
1997 F350: Regular cab XLT, 7.3L PSD, 5 speed, 4x4, 3.55 - Some Stuff
2000 F350: Crew Cab, Lariat, 7.3L PSD, 6 speed, 4x4, 3.73 - More Stuff
2001 VW Golf: 4 door, GLS, 1.9L TDi, 5 speed - Darn near makes fuel!
Dieselfever is offline
post #8 of 31 (permalink) Old 10-20-2008, 06:29 AM
Tuning can make a big difference in MPG, but as you've pointed out there are many variables. I drive the same way pretty much all the time. I don't have an econo tune so I drive around in either my tow program or my "race" program. The race program consistently drops the economy about 1.5-2mpg over my tow tune just because of the aggressive nature of the fueling. This is all unloaded.
Along with driving habits good tuning should make a big difference in MPG.
I am a little confused about your comments on timing earlier in this thread. You seem to indicate that advanced timing makes the truck hard to start when cold. Advanced timing actually makes the truck easier to start cold and at the point the you have advanced the timing so much to make it hard to start it'll hard start all the time. In fact many mechanical diesels use weights or fuel pressure valves to artificially advanced the timing during cold starts.
Another thing to note is that on a powerstroke your cold start timing advance and hot running can be two DIFFERENT values (actually they are stock and change based on a number of different conditions dynamically). So you can advance the timing all you want hot and not cold, etc. So you should never have a cold start problem if the tuning is done correctly. This is of course assuming the timing changes are being done in the program itself, I have seen and read about people tricking the EOT sensor to change the timing tables and that is not the best idea.
All else aside, areodynamics and the driver are the two largest MPG factors. Well that and the large box of dead weight that is usually following my truck nearly every time it leaves the driveway
69W900A is offline
post #9 of 31 (permalink) Old 10-20-2008, 01:20 PM
Banned
I'm not being argumentative, but when I see 12 valves having a hard time starting it's because they have the timing advance set to meet the needs of the engine at full power in the higher rpm ranges and it just doesn't want to crank anymore with that much advance.
If they could retard the timing to crank it would help them. My truck cranks best at ~3 degrees advance. Course I'm sure with the lowered compression mine likes less timing than some others.
Seems like when it's cold, spraying the fuel into the cold cylinder even earlier is just going to stiffle that cylinder's ability to gain heat. Make a lot of blue/white smoke and snuff it out. Waiting a bit would seem to give the air a chance to compress farther toward TDC, gain more heat and ultimitely have a fighting chance at igniting the fuel.
Now that's just based on my observing hot rod mechanical trucks trying to crank with what is a lot of timing for idle rpm, and what I've noticed on my truck with lowered compression. So I could be missing a big portion of the puzzle and just not realize it.
Ever hear a 12v guy say, I would like to advance it a bit more, but it's my Daily Driver and if I do it'll get hard to crank in the mornings?
Charles is offline
post #10 of 31 (permalink) Old 10-20-2008, 01:39 PM
can anyone explain why people with sho b-codes and extreme tuning (i.e. 600+ hp tunes) are getting 22+ mpg running at 80+ mph?
i thought stuff like that hurt your mpg, looks to me like it helped
PMRCM#1
slowleak is offline
