CNG ?????? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 10-10-2008, 04:25 AM Thread Starter
Hillbilly
Htrn38's Avatar
CNG ??????
Ok heres what i know CNG workes like propane you need a tank and a regulator inject into your air intake and wouch your MPG go through the roof. it can't be that easey can it can anyone fill in the blanks for me?
Travis
2000 7.3
AFE stage 2, Stage 2 injectors 160/100, GTP38R with WW2, DP-Tuner Stock Hi-Idle 60tow 80Eco 120 Race 140 Aggressive, 4in. Exhaust, Coolingmist water-meth
Htrn38 is offline
post #2 of 4 (permalink) Old 10-10-2008, 04:37 AM
matthewd11's Avatar
Re: CNG ??????
its just like propane. It destroys the engine over time. but all the power to ya
matthewd11 is offline
post #3 of 4 (permalink) Old 10-10-2008, 12:07 PM
Re: CNG ??????
How much time? I have almost 200,000 miles using propane on the same engine with zero bad issues. The bottom line is if you use common sense and don't overfeed either propane or CNG to your engine it will last a long time.
99.5 F-350 SRW 6 speed mods:PHP live tuned., MSD propane system, snow water injection,DDP stage 1 injectors,AFE stage II air intake,ITP boost regulater,3.5 turbo back exaust,FASS fuel system. Gulf Coast oil bypass filtration, ITP reg. return, HPX oil line , GTP 38r with 1.15,EBPV delete. 430,000 miles,Adrenaline HPOP
cantrellc123 is offline
post #4 of 4 (permalink) Old 10-10-2008, 12:20 PM
DZL JIM's Avatar
Re: CNG ??????
Biggest 'problem' is finding a source to fill your CNG tank. Every corner sells/fills LPG tanks, but good luck find a CNG refiller.
You can get a 'station' for your garage if you have Natural gas at home, but those are $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$.
On second thought, go buy one. The more they sell, the cheaper they'll get then maybe I'll be able to afford one.
DZL JIM is offline
