What chip setting for best MPG - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 22 (permalink) Old 09-19-2007, 01:27 AM Thread Starter
I have 2000 psd F250 4x4 with the edge with attuide and the evolution. When I run empty I run the evo in tow and the attuide on 3. Towing 10K I run the same. I know alot of you guys are running the Dp but I am looking at settings for all chips.
freshman is offline
post #2 of 22 (permalink) Old 09-19-2007, 01:56 AM
Re: What chip setting for best MPG
Ideally the best MPG will come from the setting with the most timing, and highest injection pressure.
That would naturally be your "hottest" tune. There exceptions however to this, if you have the cruise set and the hottest tune stabs at the throttle when you come to a hill and you see a slight puff of smoke, there went all the MPG gains you attained by using that setting.
If I am empty cruising on the interstate in relatively flat terrain, I will use my race or extreme setting, if it is a highway or more hilly on the interstate, I will use my 80 econo tune.
The 80 is the best all around for MPG.
Towing is another exception to running the higher tunes for mpg, towing I usually get the best in my tow setting, or 80.
gregrob is offline
post #3 of 22 (permalink) Old 09-19-2007, 05:04 AM
utah get me two
the more time spent here the more you will want, dp
[SIGPIC][/SIGPIC]2001 f250 4x4 cc sb 6 in lift...dp 6 pos..
glamis_dave is offline
post #4 of 22 (permalink) Old 09-19-2007, 06:00 AM
Transfer Student from TDS
w4racing's Avatar
"Gregrob"So your saying if you run your hottest setting or close to your hottest setting and grandpa drive the truck you should have better mileage than your economy tune? Im running DP's older chip.
Early 99-F250 Quad Cab LB 4x4 - Banks 3.5" exhaust, fuel tank mods, Tricumulator Spings, Pyro Gauge, Banks Big Head, Tru-cool, AirDog.
w4racing is offline
post #5 of 22 (permalink) Old 09-19-2007, 06:10 AM
Yes, you should notice a little difference.
gregrob is offline
post #6 of 22 (permalink) Old 09-19-2007, 06:18 AM
w4racing's Avatar
Well then I gonna give that a try, thats if I dont get power hungry. I think my 100 setting would be a good start, instead of my 120.
w4racing is offline
post #7 of 22 (permalink) Old 09-19-2007, 10:07 PM Thread Starter
Thanks. I bought the edge stuff before I found the diesel sites and now want the DP chip but cant justify buying it because I dont think much power will be gained over the 2 I have. Thanks For the imput
freshman is offline
post #8 of 22 (permalink) Old 09-19-2007, 10:56 PM
Don't EFN worry about it
Aljay's Avatar
Are you serious? Damn do you realize that the edge stuff is generic? I will say this because I have owned both an edge,and a superchips then I saw the light. I do have a 7.3 but all I will tell you is that you are leaving alot on the table . Get a chip from D.P. and it will be night and day. I too was a non-believer.
Tuned by T Wildman
Aljay is offline
post #9 of 22 (permalink) Old 09-20-2007, 01:13 AM Thread Starter
I was under the impression that with my staked edge stuff I wouldn't gain much. Now if I had an auto it would be alot differnt.
freshman is offline
post #10 of 22 (permalink) Old 09-20-2007, 02:10 AM
dude you dont know what your missing out on. i was the same way. them i got some DI tunes....wow is all i could say.
PMRCM#1
slowleak is offline
