Effect of ULSD fuel on Mileage??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 10-01-2008, 11:52 PM Thread Starter
An Ancient view on life
JonFord's Avatar
Location: Houston, Texas wishing I was on the Pig farm in Iowa
When ULSD fuel first came out is seemed like I was down about 1 to 2 mpg. Now, I seem to have basiclly recovered most of that loss. Anyone else with that experience?
JonFord
[SIGPIC]
1997 F-250 CC
Banks intercooler-6 position Chip and BlownAway Headers from DI
URL=
src="
border="0" alt="" />[/URL]
2003 VW Jetta TDI-----50 mpg
JonFord is offline
post #2 of 16 (permalink) Old 10-02-2008, 02:01 AM
Re: Effect of ULSD fuel on Mileage???
I have not noticed my mileage going back up any but it could just be all those miles on my truck.
99.5 F-350 SRW 6 speed mods:PHP live tuned., MSD propane system, snow water injection,DDP stage 1 injectors,AFE stage II air intake,ITP boost regulater,3.5 turbo back exaust,FASS fuel system. Gulf Coast oil bypass filtration, ITP reg. return, HPX oil line , GTP 38r with 1.15,EBPV delete. 430,000 miles,Adrenaline HPOP
cantrellc123 is offline
post #3 of 16 (permalink) Old 10-03-2008, 03:06 AM
blame the dog..
JLDickmon's Avatar
yeah, because it came out in the late fall, so it hit as "winter blend"
This site needs new newbs.
JLDickmon is offline
post #4 of 16 (permalink) Old 10-03-2008, 12:55 PM
blame the dog..
JLDickmon's Avatar
which reminds me..
my last tank-up seemed to be off a little... (only got 470 miles vs the usual 500) so I'm thinkin' they might be running the winter stuff already
post #5 of 16 (permalink) Old 10-03-2008, 01:42 PM Thread Starter
JonFord's Avatar
I can see that in Michigan, but I am not sure we get the winter fuel here in Houston.
Mine most diffenatly went down when I had to start using the ULSD. I just love the EPA.
I'll call today and see what they do to us.
JonFord
[SIGPIC]
1997 F-250 CC
URL=
src="
JonFord is offline
post #6 of 16 (permalink) Old 10-04-2008, 04:29 PM
I think i lost 2-4 mpg's across the board damn greenies.
zorak is offline
post #7 of 16 (permalink) Old 10-05-2008, 12:28 PM
DZL JIM's Avatar
Aug - Oct '07 I averaged 20 - 21 mpg with my F-250 cc.
Nov '07 I put in Stage-1 injectors (which act like stock, in stock chip setting) and a Dana 60 in the front and full F-350 suspension accessories, which raised the front of the truck about 1" and the rear about 2".
May '08 I added new BFG AT 265 tires and I now see a best average of 17.5 mpg.
The tires I replaced were 235 and worn badly. I have a hard time believing the mods I did have affected mileage that much. ??? It just seems like the fuel is different.
I could be wrong, but otherwise that means raising an already tall truck 1" and adding tires that are about 3/8" wider sucks up 3 mpg more. I just don't see that...
DZL JIM is offline
post #8 of 16 (permalink) Old 10-05-2008, 01:13 PM Thread Starter
JonFord's Avatar
We need a SCF to step in here to explain BTU's and all that technical stuff. Why should reducing sulphur cause a loss of MPG?? Or did it???????
I do know that soot levels are lower now with the advent of ULSD.
I am now getting back slightly above my previous MPG level in town, but I now have tires that ride like concrete, looking at every tail light in town and acting my age. That is a real first. lolololm
******For you unfamiliar with my use of SCF, it means a well educated guy , usually a lot younger that me , and starts with Smart College. You can fill in the last word, but is normally associated with fun bedroom activity.*******
[SIGPIC]
1997 F-250 CC
URL=
src="
JonFord is offline
post #9 of 16 (permalink) Old 10-06-2008, 12:37 PM
blame the dog..
JLDickmon's Avatar
Jim, you usually loose MPG when you put on new tires due to the increased drag from tread flex.. plus you went wider.. I can see it happening..
post #10 of 16 (permalink) Old 10-06-2008, 03:52 PM
I noticed a drop in mileage after the implementation of the ULSD. Pre-ULSD I was able to get about 19 mpg on the highway with a stock truck, now after ULSD and all the mods in the sig, I can only get in the low 18's, so it definately lowers the mileage. When the sulfur is removed, the energy content that is in sulfur is also removed, so now there is less energy per unit of fuel than before, that is why the mileage will go down with the ULSD. I am not a mechanical engineer, but I did have one thermodynamic class, and it all has to do with energy, and entropy, and blah blah blah...Basically there is just less juice in the diesel now.
2003 7.3 XLT FX4, AFE Stage 2, Regulated Return, Bowl Delete, 3/8" line from tank to heads, Pre/Post Filters, Tank mods, DP F5: 60T, 80E, 120R, 6.0 IC, 6.0 Trans Cooler, Suncoast Shift Kit, Wicked Wheel, ITP Boost Annihilator, Di Procol Optix, Straight Pipe, CCV, 285/75/16 BFG AT's
breyrw is offline
