coolmist metenol injection - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 09-16-2008, 05:23 PM Thread Starter
winkfab's Avatar
I am new to te diesel performance so bare with me on all the posts. I have done searches but havn't ran across anything on using the methenol for fuel economy just for hp to cooling the boost, Has anyone tried it? Snow claims they have a kit but it's alot of $ for it.
Wink Fab - cnc machining and fabrication
2008 f250 4x4 bone stock and ready to mod/repair
97 f350 4x4 410 gears 37 BFG, 4" exhaust, dyi, tw chip,
IDM mod, .427 sonnex valve, rsk w/sd springs, grease able 4x4 lever,Rosewood stage 2, T-500 hpop,1.0 ex housing
These trucks are like crack, you just can't leave it alone.
winkfab is offline
post #2 of 6 (permalink) Old 09-16-2008, 05:30 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: coolmist metenol injection
Any kit can be used as a MPH kit. Just start spraying a smaller injector very early on, and progressively bring in more water.
Joe
CSIPSD is offline
post #3 of 6 (permalink) Old 09-16-2008, 10:57 PM
MPG Moderator
Dave Whitmer's Avatar
Methanol, CNG, and propane. All really the same: a barely controlled auxiliary fuel with very low cetane and has to be "blowtorched" into combustion by the injectors.
They make sense if you can get them cheaper (on a $/MMBTU basis) than No.2. Otherwise, why bother?
2000 F-350 SC 4x2 6 speed
Slammed 4"
Rugged Air Dam
315,000 miles
Dave Whitmer is offline
post #4 of 6 (permalink) Old 09-19-2008, 03:07 AM Thread Starter
winkfab's Avatar
Is there any noticable mpg gain?
winkfab is offline
post #5 of 6 (permalink) Old 09-19-2008, 09:17 PM
MPG Moderator
Depends on how much alcohol you want to shoot in.
Slammed 4"
Rugged Air Dam
315,000 miles
post #6 of 6 (permalink) Old 09-19-2008, 10:05 PM
Layson's Avatar
I have never noticed a difference with mine. I just bought it for cooling only...
Layson is offline
