more efficient engine? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 37 (permalink) Old 09-15-2008, 05:51 PM Thread Starter
secondarychaos's Avatar
Is there any way that you can make the engine more efficient?
there seems to be much debate over whether or not an intake or exhaust will help. What about tuning, electric fans, advancing timing....
Dan
96 Powerstroke: 6637, downpipe to dump exhaust, 140v IDM and a shift kit.
84 Honda Sabre V65 1100: pipes, jet kit and new tires. Faster than I think I'll ever need.
secondarychaos is offline
post #2 of 37 (permalink) Old 09-15-2008, 10:35 PM
MPG Moderator
Dave Whitmer's Avatar
Re: more efficient engine?
I've been working on the MPG thing for about eight years. I've found:
1. Intake and exhaust mods do not improve MPG.
2. Electric fans replacing the engine driven fan does not improve MPG.
3. Tuning helps a little. I gained about 0.75 MPG from a one-of-a-kind custom-burned chip. All the commercially available chips improve power at the price of reduced MPG. Maybe a really, really egregious fuel hog might benefit a little more.
These engines come pretty well sorted out from the factory.
What works:
a. Numerically lower gearing.
b. Aerodynamic improvements
c. Adjusting the nut behind the wheel (the driver)
2000 F-350 SC 4x2 6 speed
Slammed 4"
Rugged Air Dam
315,000 miles
Dave Whitmer is offline
post #3 of 37 (permalink) Old 09-30-2008, 08:49 AM
utah get me two
What works:
i allways thought, a chiped truck would get better mileage than a non chipped.
provided you controlled yourself.
is this not so ?
[SIGPIC][/SIGPIC]2001 f250 4x4 cc sb 6 in lift...dp 6 pos..
glamis_dave is offline
post #4 of 37 (permalink) Old 09-30-2008, 02:36 PM
When I bought my truck I was getting a consistant 14MPG.
This truck is my daily driver and getting every drop is a big deal.
I put on a better exhaust and intake, I have a TW Chip, and a rebuilt trans.
Now I am getting 18 MPG in the city. All these figures are hand calculated.
So YES they DO help. And I've seen others that have had the same result.
1997 F350 7.3L OBS (Old Big and Slow)
3" Downpipe (cat delete 364.5 days a year)
Custom tunes by ME
AFE Intake
Rebuilt Transmission(The works-Tripple disk TQ, All Steel insides)
Old Big and Slow is offline
post #5 of 37 (permalink) Old 09-30-2008, 04:53 PM
28 cent #2
daryl4412's Avatar
Mine gets better on the highway as well..especially in my 140 with the cruise set
daryl4412 is offline
post #6 of 37 (permalink) Old 09-30-2008, 05:13 PM
is this not so ?
I think this is more true with an automatic trans than manual.
Line pressure can be bumped up to reduce slip.
Shift points, shift duration and other parameters can be changed for the better
Timing and other engine parameter adjustments will net better economy too.
So I think those with automatic trans can see better increases with a chip verses those with an automatic.
But even Dave got .75 MPG improvement with a chip, and his manual trans and of course his driving habits tuned to max MPG.
JMHO
2006 Dodge 2500 MegaCab, 4x4, Auto, 5.9L CTD
SOLD-2001 F250 Lariat CC SB 4x4 auto, 207,000 miles, linex, DP tuner 40T, 80E, 120R. 3.5 inch DP/4 inch exhaust. ATS housing. AFE stage 1, Hutch and Harpooned, HV IDM. V-10 transmission cooler. Medium build transmission. Baby terminator single HPOP, Turbomaster wastegate, 1.0 exhaust housing.
tch.280 is offline
post #7 of 37 (permalink) Old 09-30-2008, 05:15 PM
428qbird's Avatar
I so agree with Dave...
Adjustment to the nut behind the wheel is the most important change to make. On my drive in to work this morning my F350 was still above 1/2 tank and my trip meter was near 400 miles. Since making my adjustment to how I drive, this has been the normal.
2001 Ford F350 Lariat LE 7.3 PSD
Crew Cab, 4 x 4, Long Bed, Dual Rear Wheels
One Big A$$ Mistake America
428qbird is offline
post #8 of 37 (permalink) Old 09-30-2008, 05:21 PM
Busy Busy
Marty's Avatar
This would imply you are getting 21+ mpg in a dually. Unfortunately that is not happening.
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #9 of 37 (permalink) Old 09-30-2008, 06:40 PM
Cute and cuddly boys!
mazdaparts's Avatar
Send a message via Yahoo to mazdaparts
There has to be a balance of weight and HP/Torque. Your engine needs to have enough HP/Torque to move the vehicle without working too hard. If your engine doesn't have enough HP/Torque it will work harder and use more fuel. But on the flip side too much HP/Torque will use more fuel to do the same thing. And to clarify, I know that you really only need the Torque, the HP just helps you do it faster.
2002 F250 Crewcab Shortbed 4X4 Totaled 6/16/12
2000 Expedition Eddie Bauer 4x4
There are 2 rules to getting ahead.
Rule #1. Don't tell anyone everything you know.
mazdaparts is offline
post #10 of 37 (permalink) Old 09-30-2008, 08:42 PM
CSAR Bish
XTrmXJ's Avatar
Its possible, I got 22 out of my dually the other day on a road trip, with mods and driving properly it can be done
97' F-Tree Fity CC Dually, Lowerd 3/5inches, 4 inch Borla side dump prior to the duals, 6 position TS performance chip, DIY intake, home built engine brake, on board GPS and internet, custom interior
Compitition Rock Buggy, Tube chassis, 37s, air shocks, full hydro.. A load of fun
06' American Manufacture 18' dove tail trailer
XTrmXJ is offline
