203* Stat question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 09-03-2008, 06:59 PM Thread Starter
Just a Pup
blkbrd36's Avatar
Question 203* Stat question
Are there any adverse effects/problems you get when changing to a 203* thermostat on a stock/modified PSD?
- Adam -
'00 F-250 Reg Cab 6 spd. 4wd - bone stock
'68 Merc. Cougar 302 auto, Edelbrock 4bbl carb, mallory electronic ignition.
'78 F-100 Explorer, 400M block-C6 auto, 4wd (hopefully Cummins 4BT future home)
No room to list other toys
blkbrd36 is offline
post #2 of 10 (permalink) Old 09-03-2008, 07:02 PM
hotstik's Avatar
Re: 203* Stat question
Don't run the 203 t-stat with big oil. Your oil temps will run hot.
2000 F250 7.3L 4x4
2003 F250 7.3L 4x4
DP-Tuner
Empire Diesel
ITP Diesel
John Wood Automotive
One Up Offroad
Swamps Diesel
hotstik is offline
post #3 of 10 (permalink) Old 09-04-2008, 02:23 AM
MPG Moderator
Dave Whitmer's Avatar
I haven't had any problems with it.
2000 F-350 SC 4x2 6 speed
Slammed 4"
Rugged Air Dam
315,000 miles
Dave Whitmer is offline
post #4 of 10 (permalink) Old 09-04-2008, 02:30 AM
SD26's Avatar
I've had it now in two vehicles. Smooths out the thumpiness at cruise speed. A little better mileage too.
I'm stock other than a DP Tuner. Check my signature.
Dave
2005 E350 6.0PSD
2003 Excursion Limited 4WD 7.3PSD - Sold
1996 E350SD dually 7.3PSD - Gone!
2002 VW Jetta TDI - stock
2007 Escape Hybrid
1999 Kaw KLR650 - 17/42 gearing
SD26 is offline
post #5 of 10 (permalink) Old 09-04-2008, 02:51 AM
hotstik's Avatar
I had the 203 t-stat before I did injectors or big oil. With the truck in relatively stock form, the 203 delivered what it promised, and I was very happy with it. However, as I said above, it does not agree well with big oil.
2000 F250 7.3L 4x4
2003 F250 7.3L 4x4
DP-Tuner
Empire Diesel
ITP Diesel
One Up Offroad
Swamps Diesel
hotstik is offline
post #6 of 10 (permalink) Old 09-04-2008, 03:03 AM
SD26's Avatar
What's the increase in MPG with "big oil"?
Dave
2005 E350 6.0PSD
2007 Escape Hybrid
SD26 is offline
post #7 of 10 (permalink) Old 09-04-2008, 06:31 AM Thread Starter
Just a Pup
blkbrd36's Avatar
thanks *stik. As of right now It doesn't look like I'm going to have the cashflow for awhile, so the "too hot w/big oil issue" shouldn't be a problem.
- Adam -
blkbrd36 is offline
post #8 of 10 (permalink) Old 02-20-2012, 01:24 AM
Ghyslain's Avatar
Howdy,
Just put the 203 Stat in my late 1999 F-250. No mileage checks yets, but seems to run smoother. Also, I like the quick warmer cab in the winter. Thanks to all in psn for the tip!!!
Ghyslain
Ghyslain is offline
post #9 of 10 (permalink) Old 02-20-2012, 05:36 AM
Deputydog's Avatar
I would never run that 203*!!
Deputydog is offline
post #10 of 10 (permalink) Old 02-20-2012, 06:32 AM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Originally Posted by Ghyslain View Post
Howdy,
Ghyslain
Holy 4 year old thread...
Joe
CSIPSD is offline
