cylinder deactivation - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 28 (permalink) Old 08-24-2008, 05:59 PM Thread Starter
I was wondering if it would be possable for us to deactivate two cylinders on our trucks for extra fuel ecomomy. It would be as simple as unplugging two injectors(or putting them on a toggle switch). I know this would make the truck run a bit rough. I was wondering if it would actually help much because the cylinder would still compress air, but make zero power. I guess in the long run it would be a bad idea because of the vibrations caused by a rough running engine, seems like it would be bad for the main bearings in the engine. Any thoughts??
2000psdbio is offline
post #2 of 28 (permalink) Old 08-24-2008, 07:41 PM
PSN Mega Miler
crowz's Avatar
Re: cylinder deactivation
Baddd idea. Having bad injectors I know exactly how this one plays out. Yes it makes it run bad but it gets horrible the first hill you run across skip wise and there are times it wont crank with even one injector not firing. Usually the motor has to be completely cold for it not to start from just one injector but it happens. Been there done that, way to often.
The only way to pull off better economy from cutting out injectors would be where the computer did it on its own and under certain conditions. The systems used on modern cars that do this cut them out at certain times, at no time does it just turn off so many cylinders continously.
2002 F250 SuperDuty Lariat PSD 7.3 Crew Cab 4x4 302,000+ miles.
, Valvoline Extreme Blue 5w40 Synthetic,
, Clifford Matrix 50.5x Alarm
, P3 Brake Controller, Swamps Injectors, PHP Tunes
crowz is offline
post #3 of 28 (permalink) Old 08-24-2008, 09:59 PM
Oooo, White Lightning !
Dieselboy's Avatar
I think he meens he would have a switch.....SO for starting and hills and towing he would run all 8, but on long straight trips switch off 2 and run 6........
However this would throw the PCM into a chitfit.....And by turning the other two "dead" holes into a big compressor would act more like an engine break and cause worse mileage IMHO
Race truck
2002 F-350XL RC/LB
NADP Race Trans/PCS'd
Lowered w/ traction bars
Unlimited 450/400s
S475 on Irates mount
TE 17* with Gen3
DI Headers
Dieselboy fuel system
[email protected]
599.3 on BDs dyno
Tow pig
2000 F-250XLT EC/SB
Tuned
Exhaust
Intake
Dieselboy is offline
post #4 of 28 (permalink) Old 08-24-2008, 10:42 PM
MPG Moderator
Dave Whitmer's Avatar
Cylinder deactivation is just gas-engine thinking being imposed on diesels. A big diesel, under light load, simply reduces the amount of fuel injected.
2000 F-350 SC 4x2 6 speed
Slammed 4"
Rugged Air Dam
315,000 miles
Dave Whitmer is offline
post #5 of 28 (permalink) Old 08-25-2008, 01:05 AM
What else?
smokyred's Avatar
When they de-activate cylinders in gasoline engines they don't just shut off the fuel, they have to let the compression out or you get extra drag from compressing dead air.
Also they still turn on those cylinders every 5-10 minutes. They have to keep the cylinder up to temp for when you suddenly want all 8 on.
It's not do-able (reliably) on a 7.3, or really any of the current diesels.
Dave
smokyred is offline
post #6 of 28 (permalink) Old 08-25-2008, 11:59 AM
DZL JIM's Avatar
So you don't think a V-6 Power Stroke would get better mpg than the V-8 7.3? (non-loaded, freeway driving)
DZL JIM is offline
post #7 of 28 (permalink) Old 08-25-2008, 02:31 PM
2010 BOB Points Runner up
Dieselfever's Avatar
Send a message via AIM to Dieselfever Send a message via Yahoo to Dieselfever Send a message via Skype™ to Dieselfever
There is a mechanism on the Caddy's with cylinder deactivation that just holds the exhaust valves open on the dead cyinders, so they just pump free. I believe it it oil pressure that actuates it.
-Michael
Michael
1997 F350: Regular cab XLT, 7.3L PSD, 5 speed, 4x4, 3.55 - Some Stuff
2000 F350: Crew Cab, Lariat, 7.3L PSD, 6 speed, 4x4, 3.73 - More Stuff
2001 VW Golf: 4 door, GLS, 1.9L TDi, 5 speed - Darn near makes fuel!
Dieselfever is offline
post #8 of 28 (permalink) Old 08-25-2008, 02:34 PM
Great thinking but disadvantages have been stated.
Biggest deal is the electronic valves, no camshaft, that can tune the cam profile on the fly, and float the valves for no compression on dead cylinders.
Iirc the corvette needs 60hp to maintain 65mph. In some testing they could shut half the motor off, but it's a race car not a fuel sipper and it just did not sound cool with a v4 running.
1994 F-700 Cummins 5.9 12v and Arbortech chip body
1999 International 4900 DT466E w/Allison auto, flatbed 60' rear mount altec am855 boom.
2001 F-350 7.3 4x4 reg cab, single shots, BTS trans,
35" toyo mt's on black 18" KMC addicts
2006 F-350 6.0 4x4 cc lariat, 20" stock wheels with toyo at's....waiting for studs and all that.
frashdog is offline
post #9 of 28 (permalink) Old 08-25-2008, 08:53 PM
DZL JIM's Avatar
The Cadillac Modulated Displacement motors used in '81 used electronic solenoid actuated mechanisms to alter the fulcrum point of the rocker arms for the Intake and exhaust valves on 4 of the 8 cylinders of the 6.0 motors. They did not use the electronic/oil lifter gizmos like they have today, things were much simpler then.
The idea is to keep the valves closed to retain the heat within the cylinders. You do not want the valves open, they must stay closed, so it's not as simple as just 'turning off' a couple of injectors. The Modulated Displacement system allowed the rockers to 'unseat' from their fulcrum preventing them from opening the valves. The modern systems use a spring in the lifter controlled by oil pressure to do the same thing. The Cadillac V8-6-4 motors, as they became known, had more issues than successes, due mostly to poor electronics for the time. The concept was, basically, ahead of it's time. The solenoid/mechanics hardware was quite simple and reliable, but the electronics were not. A lot has changed in the electronics community over the past 28 years.
You might be able to tell that this has been a pet project of mine for quite some time, I just need the time to follow up with it.
DZL JIM is offline
post #10 of 28 (permalink) Old 08-27-2008, 12:50 AM
MPG Moderator
It all depends on how you arrive at a “V-6 PowerStroke.”
If you manufactured a “Powerstroke”engine with only six cylinders, it might get a little better MPG at a given road load because of reduced engine friction.
If you manufactured an 8 cylinder PowerStroke engine that occasionally deactivated two cylinders the engine friction torque would remain exactly the same whether six or eight cylinders were activated, therefore the fuel consumption would remain the same.
This is IMO, an idle discussion because deactivation of cylinders is an issues that have to be addressed by manufaturers. With ULSD, Tier II, and the California diesel ban in place, I doubt we’ll see any new diesels
Slammed 4"
Rugged Air Dam
315,000 miles
