Best mileage yet from my truck... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 24 (permalink) Old 08-18-2008, 05:07 PM Thread Starter
Hoosier daddy!
Ramblin'_Man's Avatar
I just took a trip down to Ohio to visit my girlfriend this past weekend and logged my best fuel economy to date... Filled up prior to leaving and got the fuel up to where I could see it in the fill neck. I even shook the truck a couple times to get a little more in. Over the trip down and part of the trip back I logged 496.2 miles before I stopped to fill up again. I was able to squeeze 25.710 gallons into the truck(yes, I shook it again and even filled it a little more than before). Do the math and that puts me at 19.3 mpg average. The trip included about 350 highway miles, one burnout for the girlfriend and lots of small town up and down hills driving. I was pleased to say the least. I did take off my 315/75/R16's and put the stock tires back on before the trip so I'm sure that helped a lot(Yes, I recalibrated the speedo for the stock tires before I left).
2001 PSD F250
Born 4/01 in KY USA,
4x4, 3.73, Ext. Cab, Shortbox...
ITP RR, CCV, Tymar Intake, Airdog, DP tuner
Ramblin'_Man is offline
post #2 of 24 (permalink) Old 08-18-2008, 05:21 PM
OBS junkie
Cat_Rebel's Avatar
Re: Best mileage yet from my truck...
That's good to hear, you use 80e the whole way?
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #3 of 24 (permalink) Old 08-18-2008, 05:38 PM
Resident Curmudgeon
Toybreaker's Avatar
Garage
Send a message via Yahoo to Toybreaker
got 18.96 avg over the last 2 tanks myself.
2001 F250 XLT 4x4 auto
Toybreaker is offline
post #4 of 24 (permalink) Old 08-18-2008, 05:49 PM Thread Starter
Hoosier daddy!
80e 75-80% of the time... I drove some in stock and 120R but that was just the around town stuff... I did take it easy on the highway though... Bewteen 65 and 70 mph the whole way and besides the burnout, I didn't get into it much driving around.
2001 PSD F250
post #5 of 24 (permalink) Old 08-18-2008, 06:53 PM
Old But Sexy
96 stroker's Avatar
thats good. cant complain about that. i just averaged 21.7. but i drive alot of highway and backroads. so that helps alot
96 F-350 CCLB ,auto with a couple 6 inch black aussie stacks, A Dp-tuner and AD injectors 66mm turbo and BD t.c...
Dads-01 7.3 4x4 Excursion..stock as could be
96 stroker is offline
post #6 of 24 (permalink) Old 08-19-2008, 12:52 PM
blame the dog..
JLDickmon's Avatar
That's great!
I've found the easiest way to get good economy (best return-on-investment) on the expressway, is to come up behind a semi and hang a couple truck-lengths back from the trailer.
On my truck, there's a better way yet... pull up behind them until the wind quits whistling across the CB antenna and co-ax.. then just sit there.
18-21 mpg depending on terrain is an easy target, at that point.
This site needs new newbs.
JLDickmon is offline
post #7 of 24 (permalink) Old 08-19-2008, 03:00 PM
i bet if you would have left your taller tires on you would have gotten better. so far my best mileage has been with 35's.
PMRCM#1
slowleak is offline
post #8 of 24 (permalink) Old 08-19-2008, 09:20 PM
matthewd11's Avatar
I get about 19-21 if i'm easy on it with the setup in sig. Warm up on stock and then run it on 80e.
matthewd11 is online now
post #9 of 24 (permalink) Old 08-20-2008, 12:43 AM
MPG Moderator
Dave Whitmer's Avatar
JLDickmon:
Wayne Gerdes, the guru of the hypermilers, drafts semis all the time. He gets unbelievable MPG. Here’s his manifesto.
http://www.cleanmpg.com/forums/showthread.php?t=1510
If your ticker will take the stress of prolonged driving where you can’t see anything but that semi in front of you, you are a better man than I am.
2000 F-350 SC 4x2 6 speed
Slammed 4"
Rugged Air Dam
315,000 miles
Dave Whitmer is offline
post #10 of 24 (permalink) Old 08-26-2008, 05:56 PM
Resident Curmudgeon
Toybreaker's Avatar
Garage
I have no issues getting behind a Semi on the interstate but the truck drivers have an issue with it.
Rolled 13 mpg pulling 5700Lbs from sierra vista Az to San diego on sunday 24 Aug 2008
keeping it around 70 (speed limit was 75 for most of it and even the big rigs were blasting past me) in az and drafting semi's in california until the "hill" on the 8 between ocotillo and the golden acorn casino.
adjusting the nut has the greatest effect on mileage hands down.
