gained 2.5-3 mpg in 5 minutes!!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 20 (permalink) Old 09-21-2012, 01:31 PM Thread Starter
SledDogg's Avatar
Well I had read a thread about being able to grease our front wheel bearings via the vacum line port. Since I have manuel hubs I had a black rubber plug on it. My front stub shafts seem to go too often. I was on the roads and had to do something. I took my Amsoil 2000 filled grease gun and put about 60 pumps into each port just holding it tight. Well I deliver new travel trailers. I've gone from 16.5-18 mpg empty to 20-22.45 EVERY single tank empty. It also feels free rolling where it would drag down apon backing out of throttle. I have put about 12,000 miles on it over the last two weeks and it is consistane. Towing is up about 1/2-1mpg same trailer. my truck has 420,200 miles now.
06' F250 Harley Davidson Edition(Factory 2.5" lift)CCSB-blue sping kit, ARP, gaskets up, Driven Diesel Coolant Return, Sinister Diesel Coolant filter, Rotella ELC, SCT X4, 55gal Aluminum Fuel tank, B & W turnover. ...Hauling New RV's daily.
02' F250 687,000 miles towing...traded to friend for a boat
SledDogg is offline
post #2 of 20 (permalink) Old 09-21-2012, 10:23 PM
Weatherlite's Avatar
Garage
Re: gained 2.5-3 mpg in 5 minutes!!!
Hand calculated? Either way, I haven't seen the thread talking about lubing like you're talking about and a quick search didn't lead me to anything easily identifiable as talking about that. Any chance you could like, cuz that would be something useful to know how to do.
Weatherlite is offline
post #3 of 20 (permalink) Old 09-22-2012, 12:44 AM
Ford With Out Tax Money
snakedoc's Avatar
i grease mine thought the abs hole works great.
i would think that the vacuum line might get plugged and hubs not works?
Matt PAA #117 99.5 F-250 XLT CC SWB 4x4 4R100 Warn M12000 GPR-LED. Foil Delete. 6637. 0.50. AC. Isspro Dual Pyrometer. AeroForce. FRx. HPx. DIY SS Fuel Lines. 03 HeadLights. 4" SS Exhaust. 6.0L Trans Cooler. BTS Tunes. Custom Lighted Tuner. IH Up Pipes. EPBV Delete. AIH delete. Isspro Boost Trans. Van Turbo WW2.
snakedoc is offline
post #4 of 20 (permalink) Old 09-22-2012, 11:41 PM
ewxlt's Avatar
WHOA. Congrats. What's your mileage goal?
2006 F250 CC FX4 leveled on 285/75/18
by
, on Flickr
ewxlt is offline
post #5 of 20 (permalink) Old 09-23-2012, 04:09 AM Thread Starter
SledDogg's Avatar
I hand calculate virtually every tank. I fill er up till the neck is full takes.forever. I'm a trailer transporter so I rack up miles fast. Most weeks I put on 4-5k. Have manuel hubs so no issues there. But there are seals on each side of the uni-bearing, so pushing the grease into it will find it's way into the bearing. Should also lube the small stub axel bearing. Tomorroe I'll search for.the thread.
SledDogg is offline
post #6 of 20 (permalink) Old 10-23-2012, 12:22 AM
Greyduty's Avatar
I would love to get 20+ mpg. Right now I'm only getting 12-13. I'm willing to try anything reasonable to get better mpg. I just cleaned out my EBPS. Damn that thing was clogged bad.
Greyduty is offline
post #7 of 20 (permalink) Old 10-23-2012, 06:42 AM Thread Starter
SledDogg's Avatar
Bad EBPV sensor tube will kill mileage. I'm now at 432,862 miles. I'm about to pull a 29'the Rubicon toy hauler 2400bound mi to Eugene,OR.
SledDogg is offline
post #8 of 20 (permalink) Old 10-23-2012, 12:16 PM
Greyduty's Avatar
How noticeable was the increase in mpg after cleaning it? Was it like 2mpg better?
Greyduty is offline
post #9 of 20 (permalink) Old 10-23-2012, 07:06 PM
MPG Moderator
Dave Whitmer's Avatar
If you drove that long with that much drag from an unlubed front end, I'd recommend an inspection of the machinery.
2000 F-350 SC 4x2 6 speed
Slammed 4"
Rugged Air Dam
315,000 miles
Dave Whitmer is offline
post #10 of 20 (permalink) Old 10-24-2012, 01:13 AM
Juniorssrollin's Avatar
Are you talking about the grease fittings in the axle shafts on each side?
Sent from my DROID RAZR using AutoGuide App
2005 CCLB FX4- studded, blue spring, 6.4 banjo bolts, 6 inch lift and 35" Nittos
Juniorssrollin is offline
