10 mpg on 6.4l - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 08-01-2012, 05:04 AM Thread Starter
10 mpg on 6.4l
Hello my dads truck is a 2008 Ford F-350 6.4l Powerstoke Turbo diesel and it has a 6' Pro Comp CS9000 lift kit and Michnaline stock tire size michelin X-ICE snow tires.
We are getting around 10 mpg with this rig.. what are some things we can do to dramaditcly increase the mpg for this truck. thanks
2354bill6 is offline
post #2 of 4 (permalink) Old 08-01-2012, 05:33 AM
Re: 10 mpg on 6.4l
Simple things like a intake tuners and a DPF delete exhaust are the easiest way to get better mpg. Ha you could take the rig down to stock size and might pick up a little there too. But the DPF delete was what i seen as the biggest gain.
Whiskey9er is offline
post #3 of 4 (permalink) Old 08-02-2012, 02:42 PM
MPG Moderator
Dave Whitmer's Avatar
Re: 10 mpg on 6.4l
I'd suggest reading the six "stickies" on this forum. they cover a lot of accumulated wisdom from literally hundreds of guys on what works and what doesn't.
DPF delete can't hurt and getting back to factory-sized rubber and losing the lift are big factors.
10 MPG is disgraceful.
2000 F-350 SC 4x2 6 speed
Slammed 4"
Rugged Air Dam
315,000 miles
Dave Whitmer is offline
post #4 of 4 (permalink) Old 08-06-2012, 01:27 PM
one2nine's Avatar
Re: 10 mpg on 6.4l
Get rid of the lift for one. The words mileage and lift should never be in the same sentence. Getting rid of the dpf is the biggest mileage booster. Running a quality tuner and/or custom tunes help with mpg's.
2010 F250 CCSB - 73mm atmo, II pump, 60% nozzles, no limits intake, etc - sold
one2nine is offline
