I Might Have Hit The Wall - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 29 (permalink) Old 07-17-2008, 09:21 PM Thread Starter
MPG Moderator
Dave Whitmer's Avatar
I always thought I could get to 30 MPG with this truck, but to do so I needed more help from my gearing. I figured an overdrive could do it.
Wrong!
It mght get me to 30 MPG, but I'd need to be Bill Gates to afford it.
First, the nearby US Gear rep - a respected and reliable firm (Scheide) told me the no longer installed US Gear overdrives because they could not get parts. That's sad. US Gear was once reliable, but US manufacturing is in free fall so it is a plausible problem.
Gear Vendors is still in the business, but the quote was $5,000 installed. $5,000! To justify that I'd have to drive more than the distance to the moon - 278,000 miles or so.
Maybe its time to admit I've gone as far as possible and get something else.
2000 F-350 SC 4x2 6 speed
Slammed 4"
Rugged Air Dam
315,000 miles
Dave Whitmer is offline
post #2 of 29 (permalink) Old 07-17-2008, 09:25 PM
Busy Busy
Marty's Avatar
Re: I Might Have Hit The Wall
Put a cummins in it lmao... seems to be the answer to everything!
I know a local guy claiming 33 mpg and he's got 2wd ext cab like you but it's not lowered, a long bed with 3.55 gears, an overdrive unit, and a small air damn. Hauls around his auxillary fuel tank and fills up every 2,000 miles or so lmao.
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #3 of 29 (permalink) Old 07-18-2008, 03:27 AM Thread Starter
MPG Moderator
I hear all these Cummins guys and their claims, but they are never willing to demonstrate, so pardon me if I discount these claims.
Slammed 4"
Rugged Air Dam
315,000 miles
post #4 of 29 (permalink) Old 07-18-2008, 04:46 AM
time for injectors
bet that would put you very close to 30
PMRCM#1
slowleak is offline
post #5 of 29 (permalink) Old 07-18-2008, 05:25 AM
Crazy Talk
powerstrokenstang's Avatar
Send a message via AIM to powerstrokenstang
Originally Posted by slowleak View Post
time for injectors
some single shots
1996 F-250 ex-cab -D60- Motor,fire hoses-Nate,Tuning,Cam-Matt R,P-rods,dummy plugs-Wipe Out,Huffer-Engineered diesel,Carson,Gen3,Idm-Swamps,Rods,studs,fire rings-WOP,Clutch-Valair
455/400's in,S475 T-6 mounted
'84 f-350 2wd, 6.9l, 4spd, drw, flatbed. For Sale
powerstrokenstang is offline
post #6 of 29 (permalink) Old 07-18-2008, 06:26 AM
OBS junkie
Cat_Rebel's Avatar
I tend to agree, it's proven single shots do better then splits in the MPG department.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #7 of 29 (permalink) Old 07-18-2008, 01:25 PM
DZL JIM's Avatar
If you could install it yourself, you'd be way ahead. I've seen them new for $2500 everywhere, and on ebay even less.
Contact this guy and see if he can help you: [email protected].
A diesel mag a while ago did up a reg cab dually cummins for mileage. All they did was air up the tires, fold the mirrors in, rolled up the windows, taped off all the joints/gaps in the front of the truck, feathered the throttle and got like 27 - 28 mpg, IIRC. Not that the mag people are always the best sources for testing...
I have had quite a few people tell me Single Shots are more economical than Splits...
DZL JIM is offline
post #8 of 29 (permalink) Old 07-18-2008, 04:43 PM Thread Starter
MPG Moderator
Yeah, I read the "Diesel Power" article, too. They drove no faster than 40 MPH.
A self-install is beyond my capabilities. I can't cut and rebalance the drive shaft.
Slammed 4"
Rugged Air Dam
315,000 miles
post #9 of 29 (permalink) Old 07-18-2008, 04:44 PM
Busy Busy
Marty's Avatar
Sport mirrors, roll pan, narrower tires, aluminum or plastic bed (like a hauling bed)...
Elkton, Maryland
Marty is offline
post #10 of 29 (permalink) Old 07-18-2008, 05:05 PM
OBS junkie
Cat_Rebel's Avatar
The shop up here only charges $80 to cut & re-balence a shaft. You give them the mesurements & they will build it for you.
RIP Will Iott
