in town driving question with dp tuner chip - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 12-28-2011, 03:51 AM Thread Starter
Heres what Im thinkin. I had dp tuner send me a chip with a setting for towing (80hp), economy (80hp), high idle and stock setting.
Supposedly when you drive sensible you can get better mpg with the 80hp economy setting but here is what im wondering. when Im set on my 80 economy in town my truck run around town say 35mph or so it will stay 1 gear lower than when Im in the stock setting. cruising at approx 35 I can reach up to my switcher and toggle to "stock" and the truck will immediately shift and the rpms drop so the truck is running a lot less rpms. With that being said, I just figured I would get better mpg in town on my stock setting than my 80economy in this situation but thats just what im thinking..... Thats why I wanted to ask on here....
My question is should I just run in town on the stock setting and just run the 80 economy once im out of town and running on highways????
Im in the process of testing this but i don't drive it much so it may take me a while to find out.
By the way, kudos to dp tuner. Truck is a different animal than the dog she used to be. Pulling my trailer on the tow setting is where I notice the most difference. Good product!
powerstrokecrazed is offline
post #2 of 4 (permalink) Old 12-28-2011, 03:55 AM
needs more fuel
96f350psd's Avatar
Re: in town driving question with dp tuner chip
i would run the 80hp economy in town. i think if you run that setting it will keep the engine from lugging and net better mpg.
-Mason
96 f250 xl reg cab lwb 7.3 zf-5 3.5" straight pipe with
87 f150 xlt 302 original aod 3:55s straight pipes
90 bronco 6" lift 35s 302 aod, locked rear end
89 f150 302 aod 4x4 15x8 mb razors 33" swampers
And like paul said, a smoke tune on 90cc injectors is about as useful as dial up internet when trying to watch porn.
96f350psd is offline
post #3 of 4 (permalink) Old 12-28-2011, 04:33 AM
The tow settings change your shift points when hauling. just like the tow haul mode on the chevy's. I would run stock in town and 80hp while towing or on the highway. my truck has a 80hp program flashed on it but i have a six speed so it gets me better mileage because i can control the shift points.
RLSCOAL is offline
post #4 of 4 (permalink) Old 12-28-2011, 08:06 PM
You paid good money to buy a chip from an expert in powerstrokes and that expert created an economy tune. I would start by trusting that investment and seeing what happens.
2000 F350 SRW, 4wd, CCSB, PSD
Lowered rear end to F250 height, 4" exhaust w/ muff, foil delete, AIH delete, Ford AIS intake, tru-cool trans cooler, autometer under dash pod and gauges, Mile Marker hubs, 04 headlights, soft tonneau
18' 10k rated PJ car hauler
26' 7500# Creekside RV Trailer
Kioti CK30 tractor
Highbeam is offline
