Towing MPGs - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 36 (permalink) Old 12-28-2011, 01:44 AM Thread Starter
STILL LEARNING
Bradbilt's Avatar
Towing MPGs
What ar you all getting towing?
This past weekend i did 400+ miles towing with my OBS CCSB 7.3 5speed 4:10 truck . Loaded I figured i was grossing 17-18k. Empty w/trailer I figure 10,500.
I got 13.5mpg w just trailer and 10 with the trailer loaded. All the while @70mph
Bradbilt is offline
post #2 of 36 (permalink) Old 12-28-2011, 02:36 AM
MPG Moderator
Dave Whitmer's Avatar
Re: Towing MPGs
All depends on what you are towing, and the terrain.
2000 F-350 SC 4x2 6 speed
Slammed 4"
Rugged Air Dam
315,000 miles
Dave Whitmer is offline
post #3 of 36 (permalink) Old 12-28-2011, 03:49 PM Thread Starter
STILL LEARNING
Bradbilt's Avatar
Re: Towing MPGs
I was towing another truck and a mix of PA highway and back county roads
Bradbilt is offline
post #4 of 36 (permalink) Old 12-28-2011, 08:04 PM
Re: Towing MPGs
I get about 11-12 towing a 6000 lb Nash 25' long RV trailer or a 7000 lb tractor/car trailer load. It does not matter what terrain. Towing is always under 65 mph, usually 60 using OD whenever possible.
Really a fuel pig when towing but all honest drivers will report very similar numbers nomatter which brand.
2000 F350 SRW, 4wd, CCSB, PSD
Lowered rear end to F250 height, 4" exhaust w/ muff, foil delete, AIH delete, Ford AIS intake, tru-cool trans cooler, autometer under dash pod and gauges, Mile Marker hubs, 04 headlights, soft tonneau
18' 10k rated PJ car hauler
26' 7500# Creekside RV Trailer
Kioti CK30 tractor
Highbeam is offline
post #5 of 36 (permalink) Old 12-28-2011, 08:15 PM
WOOOOO!!!!!
Dustball8504's Avatar
Re: Towing MPGs
2008 F-250 CCSB 3.73 Automatic.
First load grossed a little over 21k, second over 23k and 13k for both unloaded. Got 12.2mpg for the tank hauling them to the scrap yard in Stoystown, its a pretty easy pull except for one part that's probably 2-3 miles up a mountain and running 50-55mph.
Hauled 6 loads like this on hilly backroads to coat my driveway, they each grossed between 20k-21k and 11k unloaded. Got 12.4mpg for the tank on them. All pulled in the Spartan 210 Tow Performance.
2008 F-250 CCSB Lariat, AFE Stage 2, 4 inch straight pipe, RCD 71mm Batmosphere, DashDAQ, SCT Livewire w/IDP tunes, Traction bars, suspension stops
621RWHP [email protected]
Elkton, MD
PSA# 60
Dustball8504 is offline
post #6 of 36 (permalink) Old 12-28-2011, 08:24 PM
WOOOOO!!!!!
Re: Towing MPGs
Your numbers sound right, my 97 ECSB, auto, 3.55 got 13mpg cruising 70-75mph grossing about 13k-14k and 15mpg with just a trailer.
Elkton, MD
PSA# 60
post #7 of 36 (permalink) Old 12-28-2011, 11:20 PM
MPG Moderator
Re: Towing MPGs
What percentage of your pickup driving is towing?
Driveaway guys tow 50% of their miles.
Slammed 4"
Rugged Air Dam
315,000 miles
post #8 of 36 (permalink) Old 12-29-2011, 12:44 AM Thread Starter
STILL LEARNING
Bradbilt's Avatar
Re: Towing MPGs
I would say 90% of my driving my CCSB has the trailer hooked to the back of it. I have a Ranger to do the daily driving stuff
Bradbilt is offline
post #9 of 36 (permalink) Old 12-29-2011, 12:47 AM
6.4L believer
08straightpiped's Avatar
Re: Towing MPGs
I usually get 13 mpg at 70 mph towing my 7500lb travel trailer. I tow with the 210 KEM tune
2007 F-350 Crew Cab Harley Edition LWB
2008 F-350 Crew Cab 4X4 "SOLD"
H&S Performance Mini Max
KEM Tuned
4" Straight piped downpipe back dpf and cat gone
pro comp extreme a/t's
08straightpiped is offline
post #10 of 36 (permalink) Old 12-29-2011, 01:04 PM
WOOOOO!!!!!
Re: Towing MPGs
I only run my 6.4 if I need it, I have a Ranger to beat around as well.
Elkton, MD
PSA# 60
