Which tune to run. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 33 (permalink) Old 06-11-2008, 08:32 PM Thread Starter
tholt34's Avatar
Which tune to run.
Ok, i like my 80 econo setting but it seems like from a dead stop i can keep my egts and my rpms down in my 60 tow setting better then the 80. Like i know the 80 has sooner shift points but the egts seem higher. like its hard to keep egts under 600 degrees. In my 60 tow i can keep the truck shifting at just under 2000 rpms and keep my egts well under 600 degrees. So i'm sure the timing and some little stuff like that are different, so which would be better fuel mileage?
Thanks.
Tim
oh yeah my truck is a 2000 4x4 extended cab automatic. Have a 6637 filter and 5 inch exhaust and dp tuner (60 tow, 80 econo, 120 race).
tholt34 is offline
post #2 of 33 (permalink) Old 06-12-2008, 12:02 AM
< pissed off pumkin.
skylinedan's Avatar
Talking Re: Which tune to run.
I don,t know what my EGT's are sence I don,t have my gauges in yet, but I,ve been running the 110 tune with my SCT and I think the millage is better than with the 80E I think I,ve only run the tow tune once or twice , never really paid attention to millage because I never run it long enough to get a good reading. I pulled my two horse in the 110 tune and think my millage was better, and I have heard others doiing this aswell unless they were puling heavy to point the EGTS got out of hand. I have gauges coming next week so its gonna be interesting to see how hot it running with what I,ve done so far and towing.
Dan
2003 F-350 4x4, Ext cab. 7.3 AFE stage II 4" turbo back exhaust, garret GTP 38, 1.15 van turbine housing,EBPV deleated, non waste gated, ATS compresor housing, WW II, bellowed up pipes, CFM + spyder conversion, Hydra chip with Bill's tunes, CCV mod, Hutched, harpooned, RR fuel system, 6.0 trans cooler, Swamps IDM, HPX.
skylinedan is offline
post #3 of 33 (permalink) Old 06-12-2008, 03:31 AM
you were towing chiped without an EGT gauge!?
Andy
I would like to thank F.A.S.T. for helping with the 2008 pulling season.
For all your fire service repair and fabrication needs. Will travel.
IDM Info Updated 11/07/08
mustang_gt_350 is offline
post #4 of 33 (permalink) Old 06-12-2008, 12:15 PM
The Fireman
big_stroker's Avatar
Its just money...
big_stroker is offline
post #5 of 33 (permalink) Old 06-12-2008, 12:54 PM
skylinedan's Avatar
I,m not pulling enough that temps should be going sky high and I live on flat ground for the most part. If I was up in the mountains it would be a different story. Besides these 7.3 are supose to be so tough or is that just a bunch of bull$hit. .
Dan
post #6 of 33 (permalink) Old 06-12-2008, 04:52 PM Thread Starter
tholt34's Avatar
I have heard higher horsepower programs get better fuel mileage but i was just wondering for my observations. So no one has any idea?
tholt34 is offline
post #7 of 33 (permalink) Old 06-12-2008, 05:46 PM
skylinedan's Avatar
I can tell you this much I dont get into the gas nearly as hard to get going from a light or I,m running down the guy in front of me so I can see it helping , but if you stuff it a nd stay there its another story I,m sure.
Dan
post #8 of 33 (permalink) Old 06-12-2008, 06:29 PM
<----Simply the best.
StrokerTurbo7.3's Avatar
Send a message via AIM to StrokerTurbo7.3
Originally Posted by skylinedan View Post
I,m not pulling enough that temps should be going sky high and I live on flat ground for the most part. If I was up in the mountains it would be a different story. Besides these 7.3 are supose to be so tough or is that just a bunch of bull. .
Dan
They are a tough motor. Probably the best International has done for our Fords so far. I'm not doubting the 6.4 though. Thats showing some potential so yea. Anyways back to your post. No diesel engine is going to be tough when your running 1500 degrees for extended amounts of time. Simple as that
No longer a proud member of PSN.
StrokerTurbo7.3 is offline
post #9 of 33 (permalink) Old 06-12-2008, 06:36 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
I run in the race setting most of the time, I like the shifting stradigy better. But the tow setting has been better as of late...
No MPG issues, as its hard to check with the 110 tank in the bed...
Joe
CSIPSD is offline
post #10 of 33 (permalink) Old 06-12-2008, 06:44 PM
OBS junkie
Cat_Rebel's Avatar
I'd worry more if your seeing 900* or more under light driving in any of the tunes. I know in 120R under normal conditions I see about the same to slightly higher EGTs over stock. That's under light driving mind you.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
