How to go about 120 miles farther on a tank of diesel. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 05-16-2008, 04:57 PM Thread Starter
Junior Mint
Remove your lift. Fix all the crap wrong w/ your truck. Drive slow.
1) Basically I pulled off my 7" Fabtach, 4.30 gears, and 37s. I went to a 2.5" lift, 3.73 gears, 35" Toyos on my same 20" Weld wheels. (still not exactly a mpg set up)
2) I fixed all the little problems on my truck and I put stock injectors in it.
I've been running so much WMO that I wasn't sure of my mpg lately but I knew it was better. But last weekend I made a run to Houston to take Grandma out for Mother's Day and I was flat out of WMO so I was able to check.
3) On my trip to Houston I rolled the windows down, set the cruise around 62 mph, cranked up some 1970s Willy, and generally kicked back. My usual mpg of around 11-12 ended up around 17-18 for this tank. That's about a 50% improvement!
Now I still had multiple full throttle passes etc but not to shabby. I'm wondering what the effect of a bit more responsive turbo would have on my mpg? Got a smaller turbine housing on the way.
I'm officially...Stroke-less.
Suns_PSD is offline
post #2 of 7 (permalink) Old 05-16-2008, 06:56 PM
PSN Mega Miler
crowz's Avatar
Re: How to go about 120 miles farther on a tank of diesel.
Not bad at all any time you can gain that much more range.
Prices ever come back down some your going to be set up for some cheap running.
2002 F250 SuperDuty Lariat PSD 7.3 Crew Cab 4x4 302,000+ miles.
, Valvoline Extreme Blue 5w40 Synthetic,
, Clifford Matrix 50.5x Alarm
, P3 Brake Controller, Swamps Injectors, PHP Tunes
crowz is offline
post #3 of 7 (permalink) Old 05-16-2008, 07:01 PM
what did you do with your othe sticks?
PMRCM#1
slowleak is offline
post #4 of 7 (permalink) Old 05-16-2008, 07:05 PM
Starting Over
kainers's Avatar
Around town driving I manually lock my TC up and idle between stop lights.Pisses people off but who cares they don't pay 4.45 a gallon
kainers is offline
post #5 of 7 (permalink) Old 05-16-2008, 11:27 PM Thread Starter
Junior Mint
GTS has got my BDs to straighten them out a bit. Honestly I've used 3 injector shops, some of them multiple times, and he is the only one that has ever made my injectors run right every time.
GTS took a set of beat AD cores (all were pulled out because they were missing from different trucks) and he made them absolutely purr.
I'll either sell the BDs or put them back in at some point when I get them back.
Suns_PSD is offline
post #6 of 7 (permalink) Old 05-16-2008, 11:45 PM
Banned
you put stock ad's with that turbo and it runs thats awesome
whiteduallyil is offline
post #7 of 7 (permalink) Old 05-19-2008, 07:27 PM Thread Starter
Junior Mint
Actually, it spools BETTER on the ADs than it did on the BDs. I've sort of learned that when you go down on injector cc you lose #'s of boost up top but spool up seems very similiar.
It spools adequate. I wouldn't call it awesome. That's why I'm trying to get another turbine housing.
Suns_PSD is offline
