350/200s 18.6 mpg - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 05-24-2011, 04:46 PM Thread Starter
Lots to learn
V-Ref's Avatar
350/200s 18.6 mpg
Is this possible or did I just get a couple tanks of the good stuff?
The math-844.9 miles / 45.4 gallons
The truck-2000 ECSB 4x4 33s leveling kit, ZF6, SRP1, 350/200s, Gearhead tunes, Sump/RR, 76mm Billet PTE DBB. Amsoil in the motor/tranny/diffs.
The driving-75% was with the cruise at 55-65 mph, 15% on gravel roads at 40-50 mph, the other 5% was conservative stop/go, the other 5% was having fun
Been tweaking with AE to get the tire diameter number dialed in...so the speed on a Garmin matches the odometer, and average timing over 2 or 3 mile markers. Got it nailed before this tank(s)...so now the Garmin/odo match at 70 mph.
Not complaining...just wasn't expecting it, and wondering if there's more to be had
If some is good, more must be better.
2000 F250 EC/SB ZF6
Unlimited 400cc/200%
Irate S467 FMW
Stecher Stealth Stage 2
Southbend DD
Irate Fuel System
Swamps HVHF IDM
WOP H11s and Springs
Gearhead/Swamps/Tyrant/Beans tuning
V-Ref is offline
post #2 of 15 (permalink) Old 05-24-2011, 05:22 PM
Banned
Re: 350/200s 18.6 mpg
Thats awesome. Really shows that a big injector can still be efficient. Good post.
donzimama is offline
post #3 of 15 (permalink) Old 05-26-2011, 04:14 PM
Junior Mint
Really good!
Best I can get on my big stuff is 14.5mpg. I suspect that my large turbo results in less efficiency under low load conditions.
I'm officially...Stroke-less.
Suns_PSD is offline
post #4 of 15 (permalink) Old 05-26-2011, 11:48 PM
Work in progress!
Big Calo's Avatar
Not out of line in my opinion. I got 19.3 in my rig but granted that was in very favorable wind conditions and 80% interstate @65mph. I was deffinately stoked.
Southern lights!!!
My big truck Early 99
(Currently trying to unfinance!)
Foil delete
5" SS Magnablows Straight Pipe
Adrenaline HPOP
AFE Stage II w/Progaurd 7
D66 Turbo
Autometer Guages
Beans 6po chip
Full Force 250/100s
CCV mod
Big Calo is offline
post #5 of 15 (permalink) Old 05-27-2011, 01:28 AM Thread Starter
Lots to learn
V-Ref's Avatar
Originally Posted by Suns_PSD View Post
Really good!
I'd like to look you up the next time I'm in south central Tx. Meant to do it a couple months ago on my last trip there.
Based on your tuners fuel vs. boost strategy, I'd thought otherwise...low boost=low fuel. If that's wrong...square me a way. Not debating...just throwing another viewpoint out there.
My old crusty non-built factory motor...isn't making near the power yours is...that might have something to do with it as well.
Have you verified your odometer/speedometer with a GPS by chance? You might be getting better mileage than you think. AE can correct for nonstandard tire sizes...
2000 F250 EC/SB ZF6
Irate S467 FMW
Southbend DD
Irate Fuel System
Swamps HVHF IDM
V-Ref is offline
post #6 of 15 (permalink) Old 05-27-2011, 01:30 AM Thread Starter
Lots to learn
V-Ref's Avatar
Thanks! I thought it might be lucky math...but this is the second 600+ mile/2 tank scenario where the math lined up over 18 mpg. Clipped the internal vent lines nearly flush with the tank when I dropped it for the sump install...so can fill the tank "to the brim" pretty consistently now....so feel pretty confident in my calculations now.
2000 F250 EC/SB ZF6
Irate S467 FMW
Southbend DD
Irate Fuel System
Swamps HVHF IDM
V-Ref is offline
post #7 of 15 (permalink) Old 05-27-2011, 01:32 AM Thread Starter
Lots to learn
V-Ref's Avatar
19.3!? So there is more to be had Are you lifted? Tire size? Truck config (EC/SC/SB/LB)?
2000 F250 EC/SB ZF6
Irate S467 FMW
Southbend DD
Irate Fuel System
Swamps HVHF IDM
V-Ref is offline
post #8 of 15 (permalink) Old 05-27-2011, 01:42 AM
Running at last...
powerstroke cowboy's Avatar
Good number V-Ref!!!
What are you running for gearing!!
Thanks!!
97 CCLB 4x4 ZF6 [email protected]
powerstroke cowboy is offline
post #9 of 15 (permalink) Old 05-27-2011, 01:53 AM Thread Starter
Lots to learn
V-Ref's Avatar
Thanks!!
Stock 3.73LS. Used the AE function to correct tire size until GPS speed and Odometer needle speed matched. Verified time over 2 and 3 mile markers.
2000 F250 EC/SB ZF6
Irate S467 FMW
Southbend DD
Irate Fuel System
Swamps HVHF IDM
V-Ref is offline
post #10 of 15 (permalink) Old 05-27-2011, 01:58 AM
Running at last...
Thanks!!
Looking good.. if you did all that to it you should be good..
