2 cycle oil for mpgs and clean fuel??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 52 (permalink) Old 04-20-2011, 11:33 PM Thread Starter
king06's Avatar
I hear alot about guys adding 2 cycle oil to help clean the diesel fuel and for mpgs. Has anybody done this and has it let to any problems wih injectors or anything else? Also what was the results as far as smotther running engine and mpgs increasing? What kind of oil(be precise please) and how much do you add? I have a 40 gallon tank....tell me what yall think and how it has hurt or helped you!!!!!!
2006 F350 cc lwb King Ranch 4x4... 4inch straight pipe dual exhaust...SCT with custom tunes by KEMRACING and new FICM by KEMRACING & S&B Intake
king06 is offline
post #2 of 52 (permalink) Old 04-20-2011, 11:49 PM
Re: 2 cycle oil for mpgs and clean fuel???
I had read on here about adding 2 cycle oil and started doing so last fall. One once per gallon of the walmart oil. I feel it has quieted the injectors down as it replaces the lubrication lost when refining the fuel down to ultra low sulfur. I have had no issues to date and will continue to add at fillups. I thought I had read it was bad for the emmisions on newer trucks. Currently I think I am around 17 mpg. I should be filling up this weekend and will know for sure.
97F250, EC LB 4x4 7.3 5sp 3:55,Donaldson Intake, Running W75/12.5/12.5 as of 2/20/12
Mudbrother is offline
post #3 of 52 (permalink) Old 04-21-2011, 12:00 AM
I used to run it in my 99 24v Cummins. It helped the mileage. Gave me about 2 or more mpg better than anything else. I am running very low on my Schaeffer DT 2000 and was wondering about 2 cycle again. I was running Valvoline Multi-purpose and running at a quart a tank, which was 38 gallons or so.
Valvoline.com Multi-Purpose 2-Cycle Engine Oil
'96 F250 SC 4x4 auto with hi miles
'95 7.3 Stroke with low miles
6637 intake
MBRP downpipe
lots of plans...little clams
Diesel Avenger is offline
post #4 of 52 (permalink) Old 04-21-2011, 12:09 AM
psn high miler
nastyf250@yahoo.com's Avatar
I do it every fill up with wal Mart tc w 3
My six liter loves it. Smoother and quieter.
No noticeable mpg gains
97 excab lb 7.3 4x4 all stock
07 cclb lariat 4x4 6.o. adios mf
2011 cclb drw 4x4 6.7 bone stock
post #5 of 52 (permalink) Old 04-21-2011, 12:44 AM Thread Starter
king06's Avatar
how many miles have yall been doing this.....anybody done it on a newer model like 2003-2009...mine is a 2006 6.0 350
king06 is offline
post #6 of 52 (permalink) Old 04-21-2011, 12:58 AM
MPG Moderator
Dave Whitmer's Avatar
The evergreen myth of two-stroke oil surfaces yet again.
I gotta write some stickies.
2000 F-350 SC 4x2 6 speed
Slammed 4"
Rugged Air Dam
315,000 miles
Dave Whitmer is offline
post #7 of 52 (permalink) Old 04-21-2011, 03:17 AM
brandon
bcangelo's Avatar
When running it I never saw any mpg changes but it did seem to smooth out at idle with it.
2002 f-250 7.3 ex cab automatic, 4'' turbo back magnaflow exhaust. tonneau cover. SOLD
2011 f-250 6.7 Lariat fx4 with lots of extras!!Sold
2011 Screw Ecoboost 4x4 with ALL the options
Excuses are like butts, everybody got one and they all stink!
bcangelo is offline
post #8 of 52 (permalink) Old 04-21-2011, 01:17 PM
Remember, I was running a Cummins, but.......I ran it a year or so, so maybe 20-25k miles? No issues. Switched to Schaeffer Diesel Treat 2000 after that. Got much the same mileage and the jug was easier to store in the tool box. I don't give a rats azz what anyone says about the mileage...my calculator didn't lie to me. It easily gained at least 2mpg on a Dodge Cummins over straight diesel. That was pulling 10k in the hills, too. Have yet to try it on the PSD I am running now. I will say this...the Schaeffer isn't doing as well with the PSD as it did with the Cummins. No mileage difference at all. Transmission fluid did as well or better, IMO. Its quite possible the two stroke won't react the same as it did in the 5.9 Cummins. My CAT and M-11 Cummins didn't really care for it either.
6637 intake
MBRP downpipe
post #9 of 52 (permalink) Old 04-21-2011, 01:40 PM Thread Starter
king06's Avatar
are you gonna try it in your psd Diesel Avenger???
king06 is offline
post #10 of 52 (permalink) Old 04-21-2011, 01:48 PM
I'll try it soon. I have a trip coming up where I can run two back to back and compare the mpg's and everything else. Probably go down with Schaeffer and come back with the two stroke. I'm not going to hold my breath, though. Even when new, my PSD's never got as good in the MPGs as my other trucks.
Cost is another consideration. Schaeffer DT is costing me less than 2 bucks a fill up. I haven't priced the oil of late, but I would bet its going to be more.
6637 intake
MBRP downpipe
