OBS convertor lockup - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 08-20-2007, 04:20 AM Thread Starter
OEM Moderator
Tom S's Avatar
What controls the firmness of the convertor lockup in the E4OD transmission? I have a BTS if that makes a difference. I am thinking it is in the pump but not really sure.
Tom
Tom S is offline
post #2 of 17 (permalink) Old 08-20-2007, 05:07 AM
Don't EFN worry about it
Aljay's Avatar
Re: OBS convertor lockup
Tom
The tune, and the V.B. the way it is set up I beleive.
Tuned by T Wildman
Aljay is offline
post #3 of 17 (permalink) Old 08-20-2007, 12:10 PM
Race car driva.......
bigblockhorse's Avatar
size of the dump hole in the pump controls firmness.
bigblockhorse is offline
post #4 of 17 (permalink) Old 08-20-2007, 04:01 PM Thread Starter
OEM Moderator
Tom S's Avatar
Jon thank for the reply. So is the firmness variable with engine power output rpm or something along those lines or does it hit the same way every time and has to be fairly stiff to prevent slipping at higher engine power output?
Tom
Tom S is offline
post #5 of 17 (permalink) Old 08-20-2007, 05:17 PM
Is the E4OD a PW modulated lockup like the 4R100?
I know Jody changed my extreme tune to a on/off lockup via programming.
gregrob is offline
post #6 of 17 (permalink) Old 08-20-2007, 05:36 PM
no the e4od's are not pwm. No matter what (e4od's), the tc will unlock on the shifts unless a tc lockup switch is used. Jon did something to my built trans where it wont flare on the shifts at all even without using the tc lockup switch, maybe he'll chime in and enlighten us. Infact several times while racing i forgot to use my tc lockup switch and it made very little difference in my times.
My ford reman (in my 97) flares on the shifts even with Jons valve body, if the trans ever has to come out i'll let him do his magic to that one aswell.
2013 ccsb 4x4-stock
99 ccsb 4x4- built to the hilt, wife's DD!
Short Bus is offline
post #7 of 17 (permalink) Old 08-20-2007, 07:27 PM Thread Starter
OEM Moderator
Tom S's Avatar
So are you saying it does that electrically or mechanically? I don't think I have any shift flare.
Tom
Tom S is offline
post #8 of 17 (permalink) Old 08-20-2007, 08:48 PM
jon did something mechanically in the trans to minimize the flair and/ or eliminate the tc unlock during shifts. Hopefully he'll see this post, cause i dont know crap about transmissions lol.
2013 ccsb 4x4-stock
post #9 of 17 (permalink) Old 08-20-2007, 10:57 PM
What issues are you having Tom?
post #10 of 17 (permalink) Old 08-21-2007, 02:53 AM Thread Starter
OEM Moderator
Tom S's Avatar
No major issues really Jon other then the convertor locks up a little harder then I would like at light throttle esp in lower chip settings. The regular shifts were that way as well but I had those tuned out for the light acceleration stuff. It is not enought to warrant pulling the transmission by any means but it is enough that I wanted to learn some more and get some knowledgeable input. I have noticed this in other transmission as well and maybe it is partially the characteristic of the beast. I am also guessing that I am more particular about it then most as I know at lot of guys like snappy shifting stuff esp barking tires at WOT
Tom
Tom S is offline
