Fluid - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 08-18-2007, 08:13 PM Thread Starter
Hated by All
Fast_Ashley's Avatar
Fluid
What's the best fluid to put in my new tranny??
PARIAH
2001 F-350
Resurection has begun.....
Fast_Ashley is offline
post #2 of 11 (permalink) Old 08-18-2007, 08:38 PM
Re: Fluid
Schaffer's or Swepco.
gregrob is offline
post #3 of 11 (permalink) Old 08-18-2007, 09:33 PM
Race car driva.......
bigblockhorse's Avatar
Re: Fluid
plain old mercon works damn good.
bigblockhorse is offline
post #4 of 11 (permalink) Old 08-18-2007, 10:46 PM
Re: Fluid
thats what i run. no heat issues so no need for synthetic.
2013 ccsb 4x4-stock
99 ccsb 4x4- built to the hilt, wife's DD!
Short Bus is offline
post #5 of 11 (permalink) Old 08-18-2007, 11:06 PM Thread Starter
Hated by All
Re: Fluid
Thanks guys
PARIAH
2001 F-350
post #6 of 11 (permalink) Old 08-18-2007, 11:07 PM
< pissed off pumkin.
skylinedan's Avatar
Re: Fluid
I agree Mercon V, I just did a fluid filter change on mine, took 8 quarts also blew out all the lines. Are you changing the cooler? They claim you can't flush the thing out, so you need to replace whern you change tranies. I,m stll not sure on mine , I still have the Ford reman here if mine goes.
Dan
2003 F-350 4x4, Ext cab. 7.3 AFE stage II 4" turbo back exhaust, garret GTP 38, 1.15 van turbine housing,EBPV deleated, non waste gated, ATS compresor housing, WW II, bellowed up pipes, CFM + spyder conversion, Hydra chip with Bill's tunes, CCV mod, Hutched, harpooned, RR fuel system, 6.0 trans cooler, Swamps IDM, HPX.
skylinedan is offline
post #7 of 11 (permalink) Old 08-19-2007, 01:47 PM
aklim's Avatar
Re: Fluid
I use Amsoil. If I can. I use synthetics.
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U front and A Rear.
aklim is offline
post #8 of 11 (permalink) Old 08-22-2007, 01:30 AM
Corona Killa
THEDIESELMAN's Avatar
Re: Fluid
So how do you like that new trans.
2007 DODGE 2500 CREW CAB 4X4 5.9 LITER CUMMINS
2002 FORD F-250 CREW CAB 4X4 POWERSTROKE
THEDIESELMAN is offline
post #9 of 11 (permalink) Old 08-22-2007, 01:34 AM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: Fluid
HUMMMM I would guess the RED kind???
Joe
CSIPSD is offline
post #10 of 11 (permalink) Old 08-22-2007, 01:36 AM Thread Starter
Hated by All
Re: Fluid
Joe.........there is just no limit to your vast knowledge
PARIAH
2001 F-350
