Buddy has reverse, no forward gears - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 08-14-2010, 10:21 PM Thread Starter
I just pulled my friends truck off the mountain! He has a 2001 Powerstroke automatic transmission. He was pulling trees out in 4 Low in reverse but then was unable to move forward in D, 2, or 1. If he revs the motor to about 3,500 and lets off it will move forward about 2 inches when the RPM's decrees to around 2,500. The Tranny was rebuilt about 35,000 miles ago and he had HD clutches put in and HD torque converter. He would like to know if anyone might know what is wrong with the limited info I gave. Thanks for the help!
otis_301 is offline
post #2 of 9 (permalink) Old 08-14-2010, 10:41 PM
PSN nerd
Re: Buddy has reverse, no forward gears
busted planetary or clutch basket. will it still go in reverse?
97 F250SC 4X4 4 LINKED ON AIR <- FOR SALE!!!!!!
00 F350CC 4x4 I NEED A FLATBED FOR IT!!!!! LET ME KNOW IF YALL KNOW ANYBODY THAT HAS ONE
JAKE is offline
post #3 of 9 (permalink) Old 08-15-2010, 01:23 AM
Low on fluid? I know is sounds silly but check the simple things first.
2000 F350 Longbed
Bullydog triple dog
MBRP 4inch exhaust
Ford AIS intake
Rixster is offline
post #4 of 9 (permalink) Old 08-15-2010, 03:00 PM
One of my transmissions had that issue. Forward clutch?
1994 F-700 Cummins 5.9 12v and Arbortech chip body
1999 International 4900 DT466E w/Allison auto, flatbed 60' rear mount altec am855 boom.
2001 F-350 7.3 4x4 reg cab, single shots, BTS trans,
35" toyo mt's on black 18" KMC addicts
2006 F-350 6.0 4x4 cc lariat, 20" stock wheels with toyo at's....waiting for studs and all that.
frashdog is offline
post #5 of 9 (permalink) Old 08-16-2010, 02:49 AM Thread Starter
Fluid is fine, nice bright red not burnt. Reverse is solid. I was thinking pump and/or TC.
otis_301 is offline
post #6 of 9 (permalink) Old 08-16-2010, 09:58 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
It certainly can't be the pump or the torque converter. They both do the exact same thing in forward and reverse. If reverse works then both the converter and pump work.
I'm betting on a mechanical failure inside the trans.
Mark
Mark Kovalsky is offline
post #7 of 9 (permalink) Old 08-16-2010, 02:52 PM Thread Starter
thanks, appreciate the input, definitely not what he wanted to hear after a $5000 rebuild 35,000 miles ago.
otis_301 is offline
post #8 of 9 (permalink) Old 08-16-2010, 03:16 PM
Crazy Talk
powerstrokenstang's Avatar
Send a message via AIM to powerstrokenstang
i was thinkin reverse and 1st use the same clutches, so prob a hard part since its clean fluid.
1996 F-250 ex-cab -D60- Motor,fire hoses-Nate,Tuning,Cam-Matt R,P-rods,dummy plugs-Wipe Out,Huffer-Engineered diesel,Carson,Gen3,Idm-Swamps,Rods,studs,fire rings-WOP,Clutch-Valair
455/400's in,S475 T-6 mounted
'84 f-350 2wd, 6.9l, 4spd, drw, flatbed. For Sale
powerstrokenstang is offline
post #9 of 9 (permalink) Old 08-16-2010, 04:47 PM
PSN nerd
5g shoulda got one hell of a warranty! and a bunch of good hard parts bts of jw transmission is less than that
JAKE is offline
