factory cooler - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 08-12-2010, 10:48 PM Thread Starter
hendricksbus's Avatar
factory cooler
will adding another cooler from a parted out vehicle help or just be a wast of time! Im talking about the little ones! 4"by 10"!
all i pull is a 13' flat bed with green wood! and next summer a 35' camper out west is in the works!! thanks!
1996 F-250,Ext.cab,LB,4x4
stock tires
180K,6 pos chip,Open air filter, 3'' down pipe,fpr mod,ccv mod
4.10s gears!
Boost, Pryo and transmission gauges
sonnax shift improver kit
bronco tank mod
hayden cooler for transmission
hendricksbus is offline
post #2 of 12 (permalink) Old 08-12-2010, 10:58 PM
Super Hauler!
Super_Hauler's Avatar
Re: factory cooler
you have a aftermarket cooler on there or something?
Super_Hauler is offline
post #3 of 12 (permalink) Old 08-12-2010, 11:27 PM
Re: factory cooler
Im guessing he means adding a external trans cooler. Mine had a cheapo from auto zone but I will be hooking up a new el cheapo one the right way since the temps did rise when I was idleing at lights in the summer.
02 f250
countryboyrob is offline
post #4 of 12 (permalink) Old 08-12-2010, 11:36 PM
Super Hauler!
Re: factory cooler
They dont come stock with a cooler. So adding another one?! I was asking if he already had one.
post #5 of 12 (permalink) Old 08-13-2010, 02:09 AM Thread Starter
Re: factory cooler
Yes there is one on the truck! a small one! would it be worth the time too add a second one! my budget wont allow me to by a big one like i want! already have another one from a ford van i parted out! I saw no problem adding a second one for more surface area!! thought id ask you guys! thanks again!!
stock tires
4.10s gears!
bronco tank mod
post #6 of 12 (permalink) Old 08-13-2010, 02:10 AM
Re: factory cooler
The obs truck have a cooler in the bottom of the rad.
02 f250
post #7 of 12 (permalink) Old 08-13-2010, 02:11 AM
Re: factory cooler
There would be no problem in added a second one. Just be sure to run the return from the stock cooler to the aux cooler then from the aux cooler to the trans.
02 f250
post #8 of 12 (permalink) Old 08-13-2010, 02:12 AM
Super Hauler!
Re: factory cooler
so do the sd but they just go in and out they dont cool much. I would get rid of the cooler you have now and go to a 6.0 cooler, they are much better and cheap!
post #9 of 12 (permalink) Old 08-13-2010, 02:14 AM
Re: factory cooler
The stock coolers work fine and so do the el cheapos from the auto parts stores. A 6.0 cooler is not cheap.
02 f250
post #10 of 12 (permalink) Old 08-13-2010, 04:02 AM
Fummins 6.0
Re: factory cooler
no its not going to hurt, will you see a big difference,... probably not, but it will help some. and dont forget to top off fluid when your done. but why do you need a aux trans cooler. are you towing that much?
06 F-250 CCLB 5.9 Cummins CR, Allison 1000 automatic transmission, o-ringed block, HAM-CAM head studs, HD valve springs, HD high forged pushrods, Twins with S480,(76x88) DDP 120hp injectors 220GPH FASS a bizillion adaptors, rear ladderbars, 20's, 5" SS MBRP turbo back custom tuned Smarty TNT by smarty
estimating 700-800 RWHP
Fummins 6.0 is offline
