DTC P1728 & P0603 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 08-09-2010, 06:36 PM Thread Starter
DTC P1728 & P0603
Can some one please tell me what DTC P1728 & P0603 is? Was driving down the road just going 60 mph and all of a sudden my od off light came on and started flashing, hooked up the programmer and it showed code P0603 and P1728. Shut the truck off and started up and it went away then about 20 minutes later it came on again.
696z400 is offline
post #2 of 14 (permalink) Old 08-09-2010, 06:40 PM
Super Hauler!
Super_Hauler's Avatar
Re: DTC P1728 & P0603
P1728 Tran Slip Error
The other one is keep alive memory
Super_Hauler is offline
post #3 of 14 (permalink) Old 08-09-2010, 07:05 PM Thread Starter
Ok I understand the Trans slip, is there anything that I can check to see exactly what the problem is?
And what is keep alive memory?
696z400 is offline
post #4 of 14 (permalink) Old 08-09-2010, 07:39 PM
All done now
Arisley's Avatar
Means your PCM has been removed from battery power (to put a chip in, batteries removed, something of that sort). Nothing to worry about.
The trans slipping needs to be worried about.
Arisley is offline
post #5 of 14 (permalink) Old 08-09-2010, 09:56 PM Thread Starter
Ok, Im sure this is a problem, my trans fluid smells burnt (horrible smell) how do I drain it and what would cause this and is there any problems with this being burnt to the internals?
1995 Ford F350 4x4 with auto. Upgrades down pipe, NAPA 6637 filter, 4" Straight pipe
2000 Peterbilt 379, New Cat C-15 and tons of chrome.
696z400 is offline
post #6 of 14 (permalink) Old 08-09-2010, 09:59 PM
Super Hauler!
Pull the pan and replace the filter, iirc it takes 15 qrts if you dont have to fill the converter which you wont unless you flush it. How long has it been since last time fluids been changed? You can burn up you converter and clutch packs but i wouldnt worry about it unless it starts acting up
post #7 of 14 (permalink) Old 08-09-2010, 10:35 PM Thread Starter
Thank you very much, Im going to do that now.
696z400 is offline
post #8 of 14 (permalink) Old 08-10-2010, 12:29 AM
All done now
Arisley's Avatar
There is a write up in the Library on flushing the tranny.
Arisley is offline
post #9 of 14 (permalink) Old 08-10-2010, 12:33 AM
Super Hauler!
where?
post #10 of 14 (permalink) Old 08-10-2010, 12:59 AM
All done now
Arisley's Avatar
Oops, sorry in the tranny section.
4R100/E4OD Trans Flush Procedure - Powerstroke Nation
Arisley is offline
