auto in my truck - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 08-03-2010, 12:55 AM Thread Starter
StroKer01's Avatar
auto in my truck
Ok can someone plase give me a list of everything I need to put an auto in my pickup
TO MUCH FORD POWER!
2002 chevy Dmax PPE hot+2
1995 Power stroke .SD swap
Rangers lead the way
StroKer01 is offline
post #2 of 15 (permalink) Old 08-03-2010, 12:58 AM
Re: auto in my truck
TC, auto trans, transfer case, auto pcm, different drive shafts.
02 f250
countryboyrob is offline
post #3 of 15 (permalink) Old 08-03-2010, 01:01 AM Thread Starter
StroKer01's Avatar
thats it?
TO MUCH FORD POWER!
post #4 of 15 (permalink) Old 08-03-2010, 01:02 AM
moore20017.3's Avatar
1. insanity
(unless you want to drag race or otherwise go fast with it)
Then about 4-5K in mods to a trans
trans
flex plate
steering column (they are the same but the shift lever lays into them)
instrument cluster
shift cable
auto PCM or just have an auto burn done on your chip
I would recommend changing the wiring harness also instead of half assing it
adapter plate between bell housing and engine
longer dowels
fill the hole in the floor pan
remove the clutch assy
remove the clutch safety switch
auto transfer case
my drive shafts worked when swapping to the standard fwiw
cross member is made for both auto/standard (two sets of holes)
buy a donor truck or find someone with the same year truck going the other way.
2008 F-250 SCLB Larait.
moore20017.3 is offline
post #5 of 15 (permalink) Old 08-03-2010, 01:03 AM
Originally Posted by StroKer01 View Post
thats it?
Mine was a basic list. moore has more know how.
02 f250
post #6 of 15 (permalink) Old 08-03-2010, 01:28 AM Thread Starter
StroKer01's Avatar
so pretty much a pain in the butt
TO MUCH FORD POWER!
post #7 of 15 (permalink) Old 08-03-2010, 01:31 AM
Yup, eaiser to swap over from an auto to a manual.
02 f250
post #8 of 15 (permalink) Old 08-03-2010, 01:37 AM
PSN nerd
I am swapping my obs to a auto with pcs controller I was soo tired of my wore out 5sp. with having a 6 speed I bet you could find someone that would want to swap.
97 F250SC 4X4 4 LINKED ON AIR <- FOR SALE!!!!!!
00 F350CC 4x4 I NEED A FLATBED FOR IT!!!!! LET ME KNOW IF YALL KNOW ANYBODY THAT HAS ONE
JAKE is offline
post #9 of 15 (permalink) Old 08-03-2010, 11:06 PM
craig just find an auto truck and either swap motors or put your goodies on it, then just sell your truck. I think that would be the best route so it doesnt make your truck a science project.
96strokerwg is offline
post #10 of 15 (permalink) Old 08-03-2010, 11:26 PM
my79f's Avatar
you could call BTS. They put an Auto in one of their employee's trucks(jeremy). It was a 6spd
my79f is offline
