transmission question? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 07-31-2010, 04:25 PM Thread Starter
stackedstroker's Avatar
I've got a Jasper class 1 tranny with a triple disc tc, suppose to be good for around 600 hp.My problem with it is that when I take off really hard there is a pause between shifts from 1st to 2nd and the rpms go way up and when it finally does shift it slams in to gear and sometimes breaks the tires loose. I know it can't be good for the tranny to shift that hard at that high of rpms, my question is can that be fixed with tuning or do I need to go with some new valve bodies? I was thinkin maybe a BTS valve body.
1999.5 F 350 crew cab dually 4x4, 330,000mi, TS 6 position, Edge monitor, Itp regulated return, sinister boost inhilator, ccv mod, afe stage ll, s475, 300cc 200% hybrids, Adrenaline HPOP, Airdog 150, Jasper class 1 full built tranny, triple disc Torque converter, AIH delete, 4" exhaust.
stackedstroker is offline
post #2 of 11 (permalink) Old 07-31-2010, 11:07 PM
smokinstroker92's Avatar
Re: transmission question?
i have the same problem with my trans but i am running a stock trans with 135xxx miles on it. The shifting really bugs me and im wondering if the it is tearing up or this is a tunning problem. I have a bts valve body that i need to put on that i was told should help but idk?
2002 F250 7.3 ccsb
300/200s
s468
Gen 3, HFHV IDM
[email protected] on fuel
smokinstroker92 is offline
post #3 of 11 (permalink) Old 08-01-2010, 12:03 AM
Yes a valve body will help.
02 f250
countryboyrob is offline
post #4 of 11 (permalink) Old 08-01-2010, 02:10 AM Thread Starter
I've done some looking around what about Bts valve body and a shifts kit. I would like some really firm shifts I hate how it just slides into gear.
post #5 of 11 (permalink) Old 08-01-2010, 02:12 AM
A shift kit is just modding the valve body.
02 f250
post #6 of 11 (permalink) Old 08-01-2010, 02:18 AM Thread Starter
Correct me if I'm wrong but doesn't a shift kit up the pressure for harder ####s, or would the bts valve body do that and the #### kit would be pointless
post #7 of 11 (permalink) Old 08-01-2010, 02:21 AM
A bts valve body is a modded valve body, which is the same thing as a shift kit. It firms up the shifts.
02 f250
post #8 of 11 (permalink) Old 08-01-2010, 02:26 AM Thread Starter
Ok thanks for the info, ill probably get the bts valve body, I hope it fixes it.
post #9 of 11 (permalink) Old 08-09-2010, 05:29 PM
Cratos's Avatar
got a jasper I will NEVER get a nother one. 1 st one had the converter go about 30.000 mile this one (under warrenty) shifts like a jaskass some times to hars sometme glike a stocker some time like it should. when I ordered it I told them i was pullinf 14.000 lbs and what mods i had / I was told No problem . since this one started acting up while i still had warrenty on it I could never get anything done about it my installer kept giving me the runaround . well next one will be BTS at leats from what i read he will stand behind his stuff. I just wish he was closer,
Blue 2012 XLT SCLB 4X4 , 38,550 miles, 3:55's & 18's Camper and Tow packages. Edge insight, Airlift Wireless compressor & Air Bag set-up, Dieslesite filter.
Cratos is offline
post #10 of 11 (permalink) Old 08-09-2010, 07:58 PM
aklim's Avatar
I wouldn't buy a BTS VB unless I was out of warranty. They can deny the warranty if they find it in there.
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U front and A Rear.
aklim is offline
