6 liter cooler in a 2000 7.3 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 07-22-2010, 01:37 AM Thread Starter
Is this a easy change? There is a good one in a junk yard near me and if I can get it for a good price I might change this while I am changing the tranny fluid.
2000 F350 Longbed
Bullydog triple dog
MBRP 4inch exhaust
Ford AIS intake
Rixster is offline
post #2 of 14 (permalink) Old 07-22-2010, 01:42 AM
Re: 6 liter cooler in a 2000 7.3
Not sure how easy but it will be well worth it.
02 f250
countryboyrob is offline
post #3 of 14 (permalink) Old 07-22-2010, 01:48 AM
CALADASH's Avatar
It aint too difficult. Just bolts in for the most part. The only advice I can give you is, when you install it, do not run the lines into the radiator. Just run them straight into the tranny cooler then to the tranny. Also, install your lines on to the tranny cooler before you drop it in!!
2002 F-250 Lariat
Im Dan,my tranny hates me no more!!"
AFE Stage 2
Power Hungry Perfomance Custom 6 Pos chip
Suncoast tranny
Isspro Boost,Tranny and EGT
H2E
Air Dog 150
Adrenaline HPOP
6.0L Tranny Cooler
FS-2500
Fluidampr
CALADASH is offline
post #4 of 14 (permalink) Old 07-22-2010, 03:11 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
I disagree. The best way to do it is keep the cooler in the radiator and the 6.0L cooler. The radiator cooler is a very effective cooler, there is no reason to bypass it.
Mark
Mark Kovalsky is offline
post #5 of 14 (permalink) Old 07-22-2010, 12:41 PM
Shaw's Avatar
Mark, how would you plumb it, radiator then 6.0 cooler, or 6.0 cooler then radiator?
"It's JUSTa 7.3"
His - 01 F-350 Reg cab 4x4 auto
Hers - 00 F-350 Crew long bed 4x4 auto
Kids - 01 EX Limited
Toy - 97 F-350 Reg cab 4X4 5spd
Shaw is offline
post #6 of 14 (permalink) Old 07-22-2010, 07:31 PM
aklim's Avatar
I wouldn't get a junkyard one. No telling why it was there or what the life it led was. Was the trans destroyed and particles went thru the cooler?
If you are replacing it, there should be no issue. If yo are installing a new one, I would think that there is one line going to the radiator and one coming back to the trans. Take the one going back to the trans and hook it into the new cooler and take the other end and hook it to the line going to the trans
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U front and A Rear.
aklim is offline
post #7 of 14 (permalink) Old 07-24-2010, 12:12 AM Thread Starter
So, is the cooler located in front of the radiator and innercooler? I just looked under my hood for about 2 seconds and didnt see anything resembling a tranny cooler. Or is it inside the radiator?
2000 F350 Longbed
Bullydog triple dog
MBRP 4inch exhaust
Ford AIS intake
Rixster is offline
post #8 of 14 (permalink) Old 07-24-2010, 12:18 AM
aklim's Avatar
It is between the radiator and the intercooler, IIRC
aklim is offline
post #9 of 14 (permalink) Old 07-24-2010, 12:38 AM
The correct way is from the front of the trans to the radiator, then to the 6.0L cooler, then to the rear of the trans.
Mark
post #10 of 14 (permalink) Old 07-25-2010, 01:14 AM
Matt-F350's Avatar
That is the way John Woods recommened when I was doing the 6.0 cooler.
Matt
Early 1999 F250 4x4 Crew Cab 7.3 liter Lariet
Matt-F350 is offline
