Loose shift lever gear selector - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 07-21-2010, 03:45 AM Thread Starter
The gear selector or shift lever is loose on my 2000 F350 auto. Sometimes I have to hold it up into park to get it to start. And it is a little sloppy from one gear to the next. Is there a easy fix? I am going to have the tranny apart in the next week or 2 for a service and shift kit install.
2000 F350 Longbed
Bullydog triple dog
MBRP 4inch exhaust
Ford AIS intake
Rixster is offline
post #2 of 13 (permalink) Old 07-21-2010, 03:52 AM
FCDP
BigBlockOBS's Avatar
Re: Loose shift lever gear selector
Check the bushings and straps on top of the steering column that hold down the shift tube. Also check the torx screws at the bottom of the shift tube where the shifter cable attaches.
BigBlockOBS is offline
post #3 of 13 (permalink) Old 07-21-2010, 03:56 AM
dieselsmoke0204's Avatar
Subscribing
Andy
2000 F350, Dually, 6speed, Flatbed, snow plow - Work Truck / Tow Pig
01 Silver PSD, lifted, roof rack, winch, snorkel- SOLD
03 Jetta TDI- DD
1999 Jeep Cherokee, lifted, locked, etc....
dieselsmoke0204 is offline
post #4 of 13 (permalink) Old 07-21-2010, 04:15 AM
boostaddict's Avatar
Same here bushings were worn out so i replaced em nice and firm!
boostaddict is offline
post #5 of 13 (permalink) Old 07-21-2010, 01:33 PM Thread Starter
sounds good, will check that. I was hoping it was not inside the tranny. Sounds like a easy fix.
2000 F350 Longbed
Bullydog triple dog
MBRP 4inch exhaust
Ford AIS intake
Rixster is offline
post #6 of 13 (permalink) Old 07-21-2010, 01:51 PM
superstroker99's Avatar
yea its not bad to do most of the ones i work on are just the screws come loose
Early 99, Rolling on 20x12 fuel hostage with 35x12.5 nitto mud grapplers. 2009 Points runner up in stock diesel and 2010 points champ in modified diesel. Truck built by Perry Perfomance in Edenton NC
superstroker99 is offline
post #7 of 13 (permalink) Old 07-21-2010, 08:44 PM
tholt34's Avatar
Yeah my first check would be the torx screws coming loose. Mine had done it and I hear about them doing that all the time.
2000 F-250 ext cab 4x4 6 spd. Glowshift gauges(egt, boost, and fuel pressure), PHP tuned, DIY intake. MBRP 5 inch straight exhaust with 6 inch tip
tholt34 is offline
post #8 of 13 (permalink) Old 07-21-2010, 09:09 PM
<---Best intake plenums
powertrip's Avatar
Yep i would bet money its the torx screws. Prolly one fell out already and the other is loose. Get bunch of fords with the same problem, here at the shop. Easy 5min fix.
RDRCM #29
"New opinions are always suspected, and usually opposed,without any other reason but because they are not already common" John Locke
powertrip is offline
post #9 of 13 (permalink) Old 07-21-2010, 09:26 PM
Ok, I looked and cound not find the torx screws....where exactly are they at?
Andy
03 Jetta TDI- DD
post #10 of 13 (permalink) Old 07-21-2010, 09:57 PM
tholt34's Avatar
If you look under the dash there should be a small rectangular box that has 2 torx screws. I can't remember which side there on. Have someone wiggle the shifter while you look for the box and you will see it moving. I think the bolts are like a t25 or something. Hope that helps some.
tholt34 is offline
